Ride: 88 crx hf
hey there i installed a d16y8 motor in my 88 crx hf now i didnt have the distributor for it or the ecu for it ....... so i installed the old distributor from the zc engine and im using the old ecu wich is non v tech bnow i had to install the old intake manifold as well to make it work so what i wanna kow is what ecu , distributor, and intake manifold do i need to make it work with the v tech ...... and what kinda wiring do i need to do thank you
the best thing to do would be to convert it all over to run OBD1 - the other option would be to leave everything as you have it and get a PR3 or a PW0 OBD0 B16A ECU and add wiring for the VTEC, knock sensor and 2nd O2 sensor - the B16A ECU is not going to have the correct fuel and ignition maps for the Y8 and you should get the ECU chipped with the maps for the P28 ECU
ZCspeed Racing |
Ride: 88 crx hf
well i hear that i need to get the ecu p28 and get the chip for it and the distributor also ..... now how would i wire the thing if i get the covgersion harness for the ecu how do i wire the v tech??? tthanx
Ride: 88 crx hf
alright so ima look for the distributor and ecu for the d16y8 and get the wiring harness for it but how do i wire the distributor and the rest of the engine
#5 |
Ride: 88 crx hf
ok so my next question is if i have the obd 2 engine i shoukld make it to an obd 1 ecu??? and if so does the computer matter ??? like is there many kind of p28 ecu or i can get which ever p28 ecu and if so wich chip should i get the mugen ? spoon sport or skunk?????????
| the worse day i've ever had at work | formby | Members' Lounge | 71 | 05-26-2007 09:52 PM |
| Autoerotica | Celerity | Members' Lounge | 10 | 07-17-2004 03:29 PM |
| Divulging how much you make to coworkers... | Loco Honkey | Members' Lounge | 16 | 10-03-2003 08:45 PM |
| Crx With D16y8 Will It Work | ragethacrx | HYBRID -> EG-EK / DC | 9 | 01-26-2003 09:53 PM |
