#1 | |
I need some ligaments!!!
Location: laurel, montucky (ten minutes out of billings)
Ride: 89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
i'm gonna be swapping a d16z6 into my manual crx and want to know what all it takes to get it done. my car is already multi point injection. need help.
car + vinyl = big hp!!! ![]() wipe your mouth, there's still a tiny bit of bullshit around your lips Quote:
( 0.o ) ( > < ) The bunny will rule teh world! Bwahahahaha!!!! |
Wrong.Your going to have to convert to obd1 also in order to actually have VTEC.Just go to Rywire - Online Store and grab up some harnesses.Your also going to need a 4 wire o2 sensor,the obd1 ecu(p28) and a cable tranny.The Z6 tranny is hydro so if it comes with the tranny just sell it and buy a crx si tranny because that HF tranny sucks bad.You arent going to be going anywhere fast with that thing.Your also going to have to swap out the driver side mount with the one from your HF motor.SO convert to OBD1 and Get a Si tranny.
#4 | |
HS TECH
Ride: dc5,mk4 gti,2nd gen civic,
#7 | |
sorry guys. was being lazy. but that sounds pretty simple. can i just change the final drive gear to lower the gear ratio to compensate for the high gears?
( 0.o ) ( > < ) The bunny will rule teh world! Bwahahahaha!!!! Last edited by turbo sol; 10-18-2006 at 02:23 PM. |
#8 |
VTEC CRX
Ride: 1990 Honda Civic Hatchback Std.
You can put a higher final drive on the old HF transmission if you want. You'll go through the gears faster for sure. But since you'll already have it torn down, you'd might as well fix the rest up as well; bearings etc.
ED6 - 1990 Honda Civic Hatchback Std. Swapping in soon: JDM D15B VTEC, Chipped P28, Teg ZXi Tranny w/ HF 5th & OBX LSD R.I.P. 11/2/2006->> 1989 Honda CRX HF - 253K |
#9 | |||
The Kicker of Elves.
Just buy an Si transmission for $75-120. Far cheaper and easier than doing transmission work.
Don't misinterpret what I say. Quote:
#10 |
VTEC CRX
If you do that, you should trust the seller before you just throw it in. If you don't trust them you'll want to check it's internals for condition or pay someone else to do so.
#12 |
VTEC CRX
ONLY the outboard (hub end) joints are different. In other words, no.
ED6 - 1990 Honda Civic Hatchback Std. Swapping in soon: JDM D15B VTEC, Chipped P28, Teg ZXi Tranny w/ HF 5th & OBX LSD R.I.P. 11/2/2006->> 1989 Honda CRX HF - 253K Last edited by BlueCrxNC; 10-23-2006 at 07:39 PM. |
#13 | |||
Just ask questions and pay attention to the answers. That'll usually tell you if someone's trying to be shadey.
#14 |
Drive it like u stole it
Ride: 88 Ef Hatch/Z6 swap
ok but hows he gona know if hes getting an si trany they all say L3 dont they??? and u can do other things besides the whole p28 ecu and harnest kit if u wanted to..Ef-honda.com look at the engines swap section some tid bits of info that might help you out but like someone said already reserch ur swap and get all the info u can get before you get all into it..
#15 | |||
Like I said, pay attention to the answers. Not just the words, the tone of the words and preferably the body language of the seller. Is he avoiding specific areas? Is he too quick to answer? Et cetera.
You can choose to run a PM6 and activate VTEC off an RPM switch. Maybe your motor will blow up like my friend's because the PM6 doesn't have the correct fuel and timing maps for VTEC. He didn't want to spend the $400 on the OBDI conversion so now he has to buy a new engine. The choice is yours.
#16 | |
VTEC CRX
| EG: D16Z6 Garage Sale!!! | D See 2 | Parts: For Sale/Trade/Wanted | 24 | 04-28-2008 10:41 PM |
| F/S A Bigs list of d16z6 And 92-95 Civic parts | Boosted4dr | Parts: For Sale/Trade/Wanted | 31 | 04-10-2005 11:03 PM |
| FS in WI: d16z6 head w/stg 2 P&P-plus more | esi42 | Parts: For Sale/Trade/Wanted | 3 | 03-28-2005 04:42 PM |
| D16z6 Parts And Sensor. | Sinner | Parts: For Sale/Trade/Wanted | 1 | 07-03-2003 01:16 AM |
| Wanted : D16Z6 Complete Head | Havok | Parts: For Sale/Trade/Wanted | 8 | 10-21-2002 11:33 PM |
