DC header install HELP
Old 07-30-2009, 10:22 AM   #1
Rep Power: 14 78civic will become famous soon enough
Default DC header install HELP
I'm NOT new to cars or header installls but HOW THE HECK do you get the 1piece header on without taking the whole front of the car off or pull the engine??
The past 3 cars I've put them on were the two piece (done in 30min) but I need it for work in a few hours
I've already pulled: fans, rad, comp, old manifold.. Even taken out the front motor mount and jacked it up.
Close but not there.. Is there something simple I"m missing?? Other mounts that need to be loosened?
Thanks for the help in advance.
E
78civic is offline   Reply With Quote
Old 07-30-2009, 11:07 AM   #2
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
can you slide it in from underneith?
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 07-30-2009, 01:49 PM   #3
NOPE, I spent a good amount of time trying all sorts of ways. Even thought that I got taken.
I had to unbol the d/s mount and jack it up and out of the mount itself. Then take off the upper rad support, that little trim above the bumper and pull the condenser foreward about 1 1/2", Get the lower flange under the pan, and push and pry. But I didn't remove that little short pipe in front of the cat.. Removed and bolted up, But I finally got it down and runnin right before work.
Thanks E
Turbo install kit Most import applications, Boost Guage Install etc.. Lee7pcNOOb Forced Induction 2 03-26-2008 11:14 AM
help w/header install,cel problem Samuels General Tech and Maintenance 3 04-06-2005 03:30 PM
header install procedure... seanjuan Engine Building 6 07-21-2004 10:28 AM
Header install = Loss of power Bns773 General Tech and Maintenance 31 10-14-2003 05:19 PM
How Do I Install.... Zerosk8r455 General Tech and Maintenance 12 04-25-2003 02:10 AM
