Greenhorn
i got a zc dohc 1.6 and am putting it in my 90 rex, i beleive it is a vtec, but how do i read the stamp on the engine to know exactly what i have? can anyone help me with this issue! Thank you for any info!
there are no DOHC ZC engines that are VTEC - all ZC engines just say 'ZC' on the block - if the engine serial number below the 'ZC' begins with a '2', the engine is from 88-91 JDM CRX/Civic Si model, OBD0 - if it begins with a '3', it is from 92-95 JDM Civic, various models, OBD1
![]() __________________
ZCspeed Racing |
the part that you are describing is the CYLinder Position Sensor which is located on the end of the exhaust camshaft on the OBD0 DOHC ZC - it doesn't say VTEC on it, it says TEC which is the manufacturer's logo (Toyo Engineering Corp.) - on the SOHC engines, the CYLinder sensor is inside the distributor, but on the OBD0 DOHC D-series engines, it is on the end of the exhaust camshaft - the sensor looks like this
![]() if your car is the DX model and you are converting it from DPFI to MPFI, two of the wires that need to be added from the ECU to the engine are for the CYLinder Sensor __________________
ZCspeed Racing Last edited by jlicrx; 08-19-2009 at 11:11 AM. |
#5 |
Greenhorn
ok, it is going into a dx but, i did a swapbefore to a sohc zc d16a? so will it already be wired for that, i know we added two more wires to the dizzy? from a five wire to a seven wire! will i still need to add more wires or is it going to work? Thanks for all your help! hows colo? i moved to florida from ft collins three years ago, and man do i miss that place!!
#6 | |
ZCspeed Racing |
#9 | |
![]() the 84-87 DOHC ZC has a valve cover with the 4 attaching bolts in the center, like this: ![]() the 88-95 DOHC ZC has a valve cover with the 4 attaching bolts on the outside edges, like this: ![]() the 84-87 DOHC ZC will not bolt into the 2nd gen CRX and 4th gen Civic as it has different mounts - the driver's side mount is on the front side of the engine, not on the end of the block - the 84-87 also used a vacuum advance ignition distributor instead of the electronic ignition advance 86-87 Integra DOHC D16A1 engines look very similar to the 84-87 JDM DOHC ZC, but they are not the same __________________
ZCspeed Racing Last edited by jlicrx; 09-30-2009 at 11:59 AM. |
#10 |
Führer Mod
jli for president!
| Honda : Del Sol DOHC VTEC HONDA DEL SOL DOHC VTEC 145K, 40K ON MOTOR/TRANNY | RSS-Bot | Auctions | 0 | 01-29-2009 03:50 PM |
| JDM Honda Acura B16A OBD-0 DOHC VTEC Engine Swap VTEC | RSS-Bot | Auctions | 0 | 08-06-2008 03:36 AM |
| B16 Cylinder Head dohc vtec gsr type r b18 ls/vtec ls | RSS-Bot | Auctions | 0 | 04-22-2008 09:13 PM |
| B16 Cylinder Head GSR dohc vtec Type R B18 ls ls/vtec | RSS-Bot | Auctions | 0 | 01-23-2008 12:03 AM |
| Front Clips & Complete Swaps Dohc Vtec / Sohc Vtec | jdm_booster | Parts: For Sale/Trade/Wanted | 2 | 01-24-2004 02:47 PM |
