Ride: 89 CRX SI (LS)
I just put this zc into a friends car. When I did the head gasket I removed cams to pull the head and I dropped the rockers out of the head. I noticed they were numbered so I put them in according to cylinder number, then noticed some numbers had more then others like there was more than 4 with number 4 on it and less than 4 with numer 2 on it. I have the motor in and running and the valves are extremely loud. I found a procedure to set them on thezcr.com done by jlicrx. I did that then double checked, but they were still really noisy. I went through procedure again .005" intake and .006" exhaust double checked. They are still very noisy, also when you let of the gas after I rev it a little the rpms drop really fast and it feels like it wants to stall but it will come back quick and idle fine. Somthing is messed up and I am not sure. Please help.
I've had the rocker shafts wear so badly (from not using a quality oil or not changing it) that no matter how many times you would adjust them they clacked.
By any chance, did you do a compression check? Were the followers really grooved? Cam lobes? Valve tips pitted/rounded? ALL plugs out, attach gauge hose, spin it over with the throttle fully open for a good 10 sec. See gauge.. Or it could just be a split/misplaced vacume line Just my .02 E |
are you adjusting the valves on the right stroke with them fully closed?
Dave Estes (owner of) DB Customs & Automotive Repair http://www.automotivecustomworld.com Just check it out!! http://www.dbcustoms.ws Free people search |
| !!new!! Ferrea Racing Dohc Zc Turbo Valves Civic !hot! | RSS-Bot | Auctions | 0 | 12-26-2007 07:33 PM |
| Skunk2 Stage1 B-Series Cams, Skunk2 Adj. Pro Series DOHC Camgears, Stock GSR Valves, | ricky05 | Parts: For Sale/Trade/Wanted | 5 | 01-15-2007 11:02 PM |
| DOHC ZC Valves | darien234 | Parts: For Sale/Trade/Wanted | 3 | 11-03-2005 11:47 PM |
| 2 valves per cylinder to 4 valves | DelSlo | HYBRID -> EG-EK / DC | 3 | 02-11-2005 08:03 PM |
| Type R Valves Vs B16a Valves | DA69 | General Tech and Maintenance | 2 | 05-15-2003 08:24 PM |
