dpfi swap problem
Old 08-31-2009, 01:54 AM   #1
Rep Power: 0 9894411 is infamous around these parts
Default dpfi swap problem
i used this dpfi swap diagram checked my wires 10 times i counted but my car want rev over 3000rpms and i did what it said help mee plzzzzzz do this diagram work good ?? i have a pr4 ecu and a si dizzy
9894411 is offline   Reply With Quote
Old 08-31-2009, 05:18 PM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
throwing any codes?
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 08-31-2009, 07:00 PM   #3
yea 4 and 6
Old 09-01-2009, 01:18 PM   #4
Ride:  1990 Honda Civic DX "The Snackbox"
Rep Power: 4 Depriesticles will become famous soon enough
myspace
Are all 4 cylinders firing?
Depriesticles is offline   Reply With Quote
Old 09-01-2009, 03:39 PM   #5
D16SiHatch's Avatar
code 4 will definitely prevent your car from running properly. that leads me to believe that either somehow your wiring is wrong, which obviously if you've checked it numerous times i'm lead to believe its not. or that the distributor is faulty. the ect code shouldn't be to hard to figure out. first make sure the 2 prong connector on the side of the cylinder head is plugged in. if so then check continuity between it and the appropriate pin on the ecu to make sure the signal is getting through. if all else fails pull the ect sender and check to see if its working properly.
91 Civic Si
Old 09-01-2009, 11:18 PM   #6
ok bro thanks but changed tht sensor and i only get code 4 now car want rev over 3 grand fuel cut and backfires ....i think this guy sold me a fucked up dizzy and if he did i will get my cash bak or he gone pay ....i put the pr4 in the ls crx tht i have and it ran perfect
Old 09-01-2009, 11:19 PM   #7
all cylinders are firing it idles fine and everything
Old 09-02-2009, 12:56 AM   #8
can you change the cnk without buying a new dizzy ??
Old 09-03-2009, 11:21 AM   #9
Ride:  1991 civic hatch dx
Rep Power: 5 Bobby17772 will become famous soon enough
dumb question but did you change over the tps because I've been reading that they tps goes in opposite directions from dpfi to mpfi
Bobby17772 is offline   Reply With Quote
Old 09-03-2009, 03:34 PM   #10
yeap i did all tht and double checked everything
88 crx dpfi swap 9894411 HYBRID -> ED-EF / DA 13 05-30-2009 01:08 AM
dpfi mpfi swap.. help!!! spider HYBRID -> ED-EF / DA 5 04-28-2008 09:42 PM
DPFI to MPFI, engine harness problem? Walterronny HYBRID -> EG-EK / DC 3 09-20-2007 02:46 PM
DPFI to MPFI problem stivic ECU's, Electronics, and Tuning 0 10-29-2006 10:21 PM
DPFI MPFI SWAP problem fixed4 life HYBRID -> ED-EF / DA 0 10-06-2006 12:18 AM
