Ecu
Old 11-27-2006, 11:36 PM   #1
Rep Power: 7 brownkobe8 is on a distinguished road
Default Ecu
ok so im plannin for a minime swap.
some say that i can just get a v tec controller to do my swap right that i connect the solenoid onto the controller. so i dont need to do nothin bout the pressure switch and the other thing i forgot what its called but ya.
and also why do you need p28 for.
also when people do the wiring why switch if others replace the harness
brownkobe8 is offline   Reply With Quote
Old 11-28-2006, 12:34 PM   #2
ef8
Rep Power: 10 ef8 is an unknown quantity at this point
To do the "mini me" correctly your going to need to convert to obd1.Just getting a VTEC controller isnt going to let VTEC work correctly.You need to convert to obd1 and get a P28.The P28 is from 92-95 D16z6.If you dont use it you arent going to have the proper fuel maps and timing adjustments which are needed for VTEC.
ef8 is offline   Reply With Quote
