I did a MPFI swap and 5 spd conversion on my crx but I cant get it to run it cranks fine and has spark and seems to be getting fuel...but the ecu code light stays lit now and it wont run...anyone think they could help? ...Its a 91 crx dx auto swapped to a d16a6 5sp..jackson racing supercharger, str cam gear, and full exhaust
That sucks cause I hooked up the one I just bought off ebay and its doin the same thing as my other 2 that I had one of them I knew worked great...I opened all three no funky smells or visual defects to either side of the board on all 3
#5 |
Ride: 89 CRX SI (LS)
my car did something similar, but the led was slightly flickering. My fuel pump was not turning on. The car would crank fine aswell. I had a bad ground for the ecu and main relay. Double check your ground on the thermostat housing that is where the ecu is grounded.
#8 |
d16a6/d16y8 "mini-me"
Ride: 1990 Honda Civic Si
Check your main relay for a bad connection, if a problem occurs in the relay then do not replace it, but simply re-solder the joints on the board in the casing. Let me know how it goes.
#9 |
Greenhorn
This is a fairly common failure on the ED cars. It may be a good idea to replace the engine grounds with new wires if they are still the originals.
| Problem Staying Running | SEIKO | HYBRID -> BA-BB /CA-CD | 3 | 04-12-2008 12:38 AM |
| Tricks to staying awake? | SlushboxTeggy | Members' Lounge | 30 | 01-25-2008 05:46 PM |
| B16a2 not staying on when cold | B16_EK | HYBRID -> EG-EK / DC | 2 | 04-26-2007 07:40 PM |
| e-brake light staying on? | CrazyAzn | General Tech and Maintenance | 7 | 09-16-2006 04:54 PM |
| Staying OBDII | denimdan | HYBRID -> EG-EK / DC | 0 | 07-29-2006 08:54 AM |
