electrical issue in my 89 civic sedan dx
Old 08-07-2009, 04:45 AM   #1
89y49rexsi's Avatar
Ride:  89 civic sedan
Rep Power: 2 89y49rexsi is on a distinguished road
Default electrical issue in my 89 civic sedan dx
well i didnt notice this until i was on my way home after buying the car but the problem is that when i turn on the left blinker my rpm guage goes nutz and starts jumping all over the place. before i put in the si guages it was the temp guage. im thinking that it is a short or a bad ground if anyone has had this problem please let me know what it took to fix it. cuz it bugs the piss out of me. thanks guys
Yes I am aware my civic is 1.6L and your Mountain Dew is 2.0L
89y49rexsi is offline   Reply With Quote
Old 08-07-2009, 04:36 PM   #2
89y49rexsi's Avatar
bump i guess nobody knows
Old 08-10-2009, 01:14 PM   #3
89y49rexsi's Avatar
comon guys i know that someone else has had this problem before help me out
Old 08-10-2009, 07:19 PM   #4
Ride:  90 crx w/zc dohc
Rep Power: 8 Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
Start with checking your grounds, I have not personally had that problem but it does sound like a bad ground causing a back feed.
What I write is my own opinion based on what I have done. Your own results may vary...
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
Fernpatch is offline   Reply With Quote
Old 08-11-2009, 04:12 AM   #5
89y49rexsi's Avatar
thats what i was thinking i checked and tightend the one under the dash by the steering column and it still does this what other grounds are there?
Old 08-11-2009, 11:28 AM   #6
myspace
Do you have a helm/haynes/chiltons manual for your car? one of those should have a complete list of grounds and locations. If not let me know and I will see what I can scrounge for you.
Old 08-11-2009, 09:04 PM   #7
89y49rexsi's Avatar
i dont have one right now but i guess i will get one in the near future. but this bugs the hell out of me--and why would my fuel guage not work with the si cluster when it worked with the stock cluster that bugs me as well
need help electrical issue t3t4delsol Civic and del Sol - EG and EK 1 10-22-2008 11:01 AM
Idle Issue / ac issue cantbetouched24 General Tech and Maintenance 1 04-29-2008 12:38 AM
help ef b16a swap electrical issue!! candyblueEG HYBRID -> ED-EF / DA 2 03-01-2008 12:10 PM
Need some help with electrical RobSter Integra 1 09-14-2006 05:43 PM
Is this electrical??? EdubbsTEG92 ECU's, Electronics, and Tuning 12 08-13-2005 05:44 PM
