Engine mount problems between 91 Civic Si engine into 93 Civic Ex Body
Old 09-02-2007, 12:18 AM   #1
Rep Power: 0 civvik is on a distinguished road
Default Engine mount problems between 91 Civic Si engine into 93 Civic Ex Body
Having problems swapping the older engine (d16a6) into a newer 93 civic ex coupe body. There is apparently different motor mount locations due to different transmissions. I'm wondering if an original tranny for the 93 has the ability to bolt into the d16a6 engine. The old tranny on the old motor puts 2 of the engine mounts (passenger side and firewall side) in the wrong place. Furthermore, there is no place on the 93 for the front engine mount. Did the 93 only have 3 mounts? Or is my 93 ex missing the front mount cause it was taken out?
civvik is offline   Reply With Quote
Old 09-03-2007, 08:58 AM   #2
jlicrx's Avatar
you need to use the 93 transmission - in addition to the mounts all being different, the 93 uses a hydraulic actuated clutch where the 88-91 uses a cable clutch - you can't run the cable transmission in the 93 car - on the driver's side end of the engine, you need to take the mount that bolts to the engine block from the 93 engine and use it instead of the mount that is on the D16A6 block
ZCspeed Racing
JDM OBD1 DOHC ZC into 91 CRX HF mount problems MotionBlur1 HYBRID -> ED-EF / DA 4 03-25-2007 02:18 PM
I have a b16a1 Engine i want to mount in 2000 HX Civic!!! Quikee HYBRID -> EG-EK / DC 7 07-20-2006 02:30 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
