few problems
Old 12-01-2006, 09:35 PM   #1
Rep Power: 7 fearfactory17 is on a distinguished road
Default few problems
im having a few problems with my 93 civic with the 1.6
the morning, or after it sits for a while when i start it up it idles at like 2 grand for 5 minutes, thats a little high for warming up isnt it? or is this normal for honda?
my speedo doesnt work and im giving up on trying to get it to work, i checked voltage going to the sensor, and it was about 4 volts, i regrounded the sensor and ran a new output wire to my aftermarket speedo and still nothing,
sometimes the speedo in my cluster will jump around when driving, but usually it does nothing, but the aftermarket does not register at all
i replaced the vss sensor too and still nothing
i was told my odometer shouldnt be working if the speedo doesnt, but that works fine.
i also have no highbeams at all, could i possibly get a wiring diagram?
any help is greatly appreciated guys
fearfactory17 is offline   Reply With Quote
Old 12-02-2006, 02:30 PM   #2
Rep Power: 7 Walshie is on a distinguished road
Check all the fuses for sure.. never know.. could just be the gauge cluster.
Walshie is offline   Reply With Quote
Old 12-02-2006, 02:59 PM   #3
all fuses are fine, my tach and all other gauges work perfectly
should i be getting more than 4 volts to the sensor?
Old 12-03-2006, 08:59 AM   #4
Rep Power: 0 2in10se is on a distinguished road
Iwould check all wires to the vss sensor again?? Just incase you know.
ONE LIFE ONE LOVE FOUR HONDAS
2in10se is offline   Reply With Quote
Old 12-03-2006, 09:00 AM   #5
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
id say it would be the gauge cluster too, but it should work on the aftermarket speedo if everything is hooked up right. If your odometer works, the vss should be good, its either wiring or a bad gauge.
Anime Informant
reikoshea is offline   Reply With Quote
1996 Nissan Altima Problems reckedracing Other Vehicle Discussions 3 10-12-2006 03:03 PM
JDM B16 Swap Problems!! itzkevin HYBRID -> ED-EF / DA 14 09-08-2006 09:08 PM
b18b/ delsol problems LS_ integra_delsol HYBRID -> EG-EK / DC 5 08-24-2006 10:05 PM
HONDA IDLE PROBLEMS 92-95 CIVIC FamilyD General Tech and Maintenance 0 05-14-2004 11:07 PM
Swap Problems Help (wireharness & Mount) Teambypass HYBRID -> EG-EK / DC 12 04-17-2003 02:03 PM
