Fuel pump wiring?
Old 12-26-2007, 06:46 PM   #1
Rep Power: 11 littlecrxVTEC is off the scale
Question Fuel pump wiring?
Well I've got a problem with the fuel pump wiring in my 89 CRX si.
I don't have a FSM so I need a wiring diagram of the fuel pump circuit.
It has a brand new pump installed, and it ran fine until I let her sit for 6 weeks. Then it wasn't getting any power to the pump. I hardwired the pump to the battery to check the pump and it works fine and the car ran.
After that, I tapped into the key on 12v ignition wire with an inline fuse and rewired the power to the fuel pump.
Now wiring is not my best area of DIY knowledge and I'm assuming I bypassed some sort of relay because now the car won't start. Its definately getting fuel into the cylinders but I think that now its flooding itself.
Any help would be greatly appriciated! THANKS
littlecrxVTEC is offline   Reply With Quote
Old 12-26-2007, 06:53 PM   #2
Lick my nuts.
93civicracer's Avatar
Ride:  '90 Accord DX, '93 Civic JDM D15B
Rep Power: 32 93civicracer is a jewel in the rough93civicracer is a jewel in the rough93civicracer is a jewel in the rough93civicracer is a jewel in the rough
Send a message via MSN to 93civicracer
Do you know where the fuel pump relay is? I just took one off another '93 civic at a junkyard today to replace mine cause it went out, on 5th gens it's in the interior next to the clutch pedal down there but I dunno it may or may not be the same for a rex. Try checking that.
Originally Posted by dacheat View Post
eh, i'm a fan of the dick beatdown.
93civicracer is offline   Reply With Quote
Old 12-26-2007, 06:57 PM   #3
I think that's what the CRX world referrs to as the "main relay" sometimes?
I believe thats the one that controls the fuel pump also come to think of it.
Its right beside the hood latch release. But I can hear it click when I attempt to start the car and click again when you release the key from engauging the starter.
Is there some way I could check it with a multimeter?
Old 12-26-2007, 07:06 PM   #4
Lick my nuts.
Yea you gotta check it with a multimeter. A service manual will tell you which terminals to check for which problem.
Old 12-26-2007, 07:08 PM   #5
Ok. How do I check it?
Thanks
Old 12-26-2007, 07:12 PM   #6
Lick my nuts.
The service manual will tell you which terminals to check ok. Then you take those clamps from the multimeter and clamp it onto the terminals the manual tells you. Now, working the multimeter itself, I dunno I couldn't figure it out I'm in highschool so my automotive teacher did that part for me.
Old 12-26-2007, 10:38 PM   #7
thanks
i need fuel pump help yankees4life9115 Civic and CRX - EF 7 02-13-2007 02:31 PM
1g crx fuel pump upgrade sdenterprise02 Civic and CRX - EW 4 01-16-2007 09:05 PM
Build a Reliable LS/VTEC hondacrxb16vtec General Tech Articles 0 10-06-2006 08:54 PM
help - fuel pump not working after head swap - 87 integra afrookie General Tech and Maintenance 20 03-20-2006 09:54 PM
2000 SI Fuel Pump Problem tuppscivic ECU's, Electronics, and Tuning 3 08-24-2005 03:44 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
