Ride: 91 crx hf
I need some serous help. I want to do the h22a swap into a 91 crx hf. this is going to be a college project. yes that mean i am going to do it at college so if you could please tell everything i need to do,buy,change, basically everything. thank you
Führer Mod
Ride: 91 civic 4dr SOHC
waste of time... you will be disapointed with the outcome. h22 in an EF will only go like high 13 low 14s all day. PLUS, it is a major pain in the ass and cost A LOT of money. But hasport has a few kits that you can get the mounts from. get the h-b kit and run a b series trans, basically just RESEARCH. Its out there.
-Carl- -Carl- __________________
streetpsi.net |
Brutal Moderator
Ride: 97 Integra LS Coupe
How do you figure? EFs and CR-Xs are pretty damn light. I've seen people do low 13s with pretty much stock H22 swaps. Add some quality bolt-ons, maybe a cam, and do some tuning, and you're looking at 12s...
#6 |
but for the price it cost to get everything DONE and running right. Plus, all the changes you need to make just to drop the motor in. Basically once you go H series in an EF, its hard to go back. I know this from experience because you need to move the pas. side mount and everything. The cost of the motor, the wiring... etc you can go JUST as fast with a cheaper project. This is my personal opinion from experience in a friends car i helped with. If you plan on keeping the car for awhile and you are set on the idea of an H series then go for it. But if you just wanna do it and see what it does, forget it. And yes, they are light. But the H series are pretty heavy.
streetpsi.net |
#8 |
if time or money is not an issue then go for the h series. Im not here to ruin your plans. It was just a personal opinion. Im a fan of b series
streetpsi.net |
#10 |
Brutal Moderator
If you don't care about how long it will take or how much money it will cost, then why wouldn't you do a K-series? They're the best four-cylinder motors Honda makes, period.
#11 |
Brutal Moderator
It won't be just as fast. No B-series engine has the horsepower, torque, or displacement that an H22 does. Do some reading on the H-series swap into your chassis and decide whether the power is worth the trouble or not...
#13 | |
streetpsi.net |
#14 |
Brutal Moderator
I understand the process of putting an H-series engine into an 88-91 Civic/CR-X chassis, and I understand the weight difference (I believe I told him to research it and see whether or not the hassle of the swap and extra weight is worth the power gains).
And yes, I agree that a built B-series can easily outrun a stock H22. I'm just saying that completely stock, an H-series equipped car will probably outrun an LS or B16 swapped car. That extra weight over the front wheels isn't necessarily a total hindrance; it can actually help with traction. I guess the purpose of the car should be considered here. Is it going to be a daily driver that needs to handle well, or is it just going to be a drag strip track whore? Also, something that never seems to get mentioned is the fact that B-series swaps add some weight as well. It's not as much as the H22 obviously, but there is a weight gain when you go to anything besides another D-series. Overall, the H22 only adds about 100 lbs over the original engine... __________________
#15 |
okay from seeing it personally... I saw this guy that was talking shit about a h22 in a ef hatch loose to a crx gsr...from what I remember the gsr has a cai. full exhaust cam gears with lsd< but this guy knew his car to the T... the h22 had an intake and exhaust.. but off the line the gsr was on his ass but ass soon as they went into 3 the gsr pulled and took him by a car and a nose....
#16 |
Brutal Moderator
Uh, ok. Thanks for the non-factual opinion based on hearsay and a possible but unconfirmed mods list. That's very helpful...
#17 |
Admin with a big stick
Ride: 2003 S2000
If you're going to recommend going through the trouble and cost of the H to B setup, just run the H to D. It's much cheaper and fits much better... plus runs just as well.
#19 | |
Brutal Moderator
Did you read what I said a few posts up? Why are you opposed to a K-series swap? If you're looking for the best engine, and time and money aren't a factor, then it's the absolute best option there is... __________________
#20 | |
so yeah I think that it would be pretty close... then you add in the weight different... center of gravity, how much they had to eat before hand and all this other shit and there would be you " non-factual" opinion.... all I have to say is that with the right things you could beat an h22 with a d series... if you want to make a track car and spend thousands on just droping in a h22 and then make that thing fast as hell with boost, nos and a little midget helping flinstone the bitch then a h is the way to go... but if you want a motor that knock the shit out of your friends friend car then just do a b series and add a few mods and call it a day... Last edited by civic_kid_666; 05-22-2008 at 02:21 PM. |
#21 |
Brutal Moderator
Well see, there ya go. You actually did get the facts this time, so now your opinion is actually useful. I was just saying that stuff like "yeah one day I saw this street race and I think the one guy had this and the other guy had that so there ya go" doesn't really contribute much to the discussion.
Honestly though, I still don't know. A GS-R swap isn't that cheap to begin with, plus it sounds like they had to put some money into it to just barely get it up to stock H22 power levels. Plus that Type R tranny with the LSD probably cost at least a grand. That's the real kicker in that equation too, the gearing of the Type R is so short and aggressive that it really does contribute to better acceleration and quicker times. Take that same tranny, mate it up to an H22 using an H2B kit and you'd probably see similar results. Plus, the cost of buying and modding the GS-R to those power levels will probably end up being pretty equivalent to the cost of just doing the H22 swap to begin with. I'm not advocating one over the other really, I'm just trying to set the facts straight. Honestly, if it came down to it, I'd probably do the B-series myself because it's an easier swap and you don't have to cut or fabricate anything... __________________
#22 | |
Brutal Moderator
#23 | ||
lets just both agree that unless hes going to become some professional driver that he should just drop a b series and not try to have a "whos dick is bigger contest"... sure it wouldbe cool to say that you have a h22 in an ef but if its a DD and your not making millions a year think about reliability being safe and do a b series |
#24 | |
Get the ef h2b set up mount wise. if its n si then it already has the wiring there that u need and u man need to cut off front stock mount off traction bar but i forget.. PS also get better suspension since motor is heavy.. |
#25 |
PS i swear people on here are retarded. If u have money the h22 is the way to go. sonce the h2b setup is over a grand usually. But if u want to make some good power enough to beat local fags like others said on here then get a "LS" n build that. NO b16 or gsr head fuck that its overrated. If ur cheap just get ARP head n main studs n spend the rest of ur money on a AFI turbo mani n a sc63 turbo n beat ass with it. Anyone who says a EF with a b series dotn handle well n is slow ur an idiot n obviously r a noob. Get with the program RICERS
| H22a Swap 93 Teg | 91integra91 | Integra | 6 | 01-28-2008 04:40 PM |
| PLEASE HELP! h22a swap | aamir786ali | Civic and CRX - EF | 4 | 11-11-2006 07:17 PM |
| h22a swap | Damien | HYBRID -> EG-EK / DC | 10 | 11-19-2003 12:11 AM |
| H22a Swap | cbrnascar0329 | HYBRID -> EG-EK / DC | 6 | 02-16-2003 12:17 PM |
| h22a swap h23a swap | 95frankenstein | HYBRID -> EG-EK / DC | 11 | 12-28-2002 06:41 PM |
