Hard shifting
Old 08-05-2009, 05:25 PM   #1
Rep Power: 13 Periculum is off the scale
Default Hard shifting
Hey gang. My ZC swapped CRX (tranny and engine) has started to get hard to shift. It only starts doing it after I've been driving for a while (30 mins or more) which is easy to do delivering pizza. It gets hard to shift out of 1st and 2nd and hard to shift into 1st, 2nd and third. Every so often, the shift into fifth gear is a little rough. None of this is consistent. I can have a very hard shift one start and at the next light it shifts as smooth as ever. In addition to this, every so often the clutch grabs sooner than expected, it still doesn't fully engage until the same point, but it'll start to put drag on the flywheel sooner. Hard to explain if that doesn't make sense. I have tried adjusting the clutch cable and it seems to have no effect.
I now leave my problem to the unlimited knowledge of my fellows here. Any help would be appreciated and please forgive me if it seems novice of me. I haven't really dealt with transmissions/clutches very often.
91 CRX HF-ZC motor and tranny swapped
-This is what the HF should have been, just a low redline.....
"My Car should Qualify as an ULEV.
An Ultra Low Expectations Vehicle" -no more that motor is outta here!
Periculum is offline   Reply With Quote
Old 08-05-2009, 05:43 PM   #2
Ride:  EF HATCH b16a swap
Rep Power: 3 gatto-is-alive is on a distinguished road
is the clutch slipping or what ??
maybe it has over worn
HELL was full so they sent me back!!!!!!
gatto-is-alive is offline   Reply With Quote
Old 08-05-2009, 05:50 PM   #3
LOWLIFE's Avatar
Ride:  91 Civic Hatchy
Rep Power: 1 LOWLIFE is on a distinguished road
Send a message via AIM to LOWLIFE Send a message via Yahoo to LOWLIFE myspace
my first thoughts are clutch as well, my next thoughts are fluid level / wore transmission
my buddies LS CRX gets hard to shift (grinds alot and doesnt wanna go into gear) when he has been driving for a while. tho his transmission is pretty wore out.
91 hatchy with an engine that makes it move along and a GSR tranny (Only good thing that car ever had).
Currently awaiting surgery on the head after some misfortune
Thants not N2O... Thats my Air Conditioning... For the engine...
LOWLIFE is offline   Reply With Quote
Old 08-05-2009, 09:12 PM   #4
I have very little if any evidence that the clutch is slipping. I deliver pizzas nearly every day and have never noticed anything that would tell me that the clutch is starting to slip.
Old 08-05-2009, 09:31 PM   #5
LOWLIFE's Avatar
maybe cable out of adjustment?
Old 08-05-2009, 10:33 PM   #6
I've moved that cable up and down to no effect. Either to the point where it drops so fast that I can't control it or that it doesn't even push far enough down to let me switch gears.
Old 08-05-2009, 10:55 PM   #7
Ride:  90 crx w/zc dohc
Rep Power: 8 Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
try changing your transmission oil. it sounds like maybe your oil is breaking down when it's hot. other than that your syncros could be shot. good luck.
What I write is my own opinion based on what I have done. Your own results may vary...
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
Fernpatch is offline   Reply With Quote
Old 08-06-2009, 03:21 PM   #8
Ride:  99 ex, d16y8 PnP, headers, exhaust, crower cam, 135whp
Rep Power: 4 josh_crewdson@y is on a distinguished road
Sounds like a Throwout bearing going bad..
josh_crewdson@y is offline   Reply With Quote
Old 08-06-2009, 04:31 PM   #9
replacing the clutch or components thereof isn't that big of a loss to me. I need to replace the rear main seal anyway. I'll try out the transmission oil and give word back on how it behaves. My driver side axle does sling oil around the engine bay, but it is debatable where the oil comes from. A drip onto the axle or coming out of the axle seal. Maybe I'm low on fluid. I'll let you guys know if the problem persists after a change.
99-00 Civic Rev Hard Turbo Kit Rev Hard RSS-Bot Auctions 0 01-05-2009 05:50 AM
Hard shifting 92 Accord afalconfan Accord 9 10-06-2008 12:20 PM
shifting dave_255 General Tech and Maintenance 6 01-06-2005 01:11 AM
Shifting @ wat RPM v13tl2omeo408 Racing and Driving Techniques 29 12-15-2004 10:12 AM
shifting stuntstere Racing and Driving Techniques 3 06-07-2004 02:39 PM
