heat hand----very strange
Old 10-15-2006, 12:38 AM   #1
Ride:  1991 Civic HB--1988 Civic HB
Rep Power: 0 1991hb is on a distinguished road
Default heat hand----very strange
I was out tonight driving around and on my way home I noticed that my heat hand would drop all the way down and then back up to normal position. It did it quite a few times but it never once went up like it was over heating. This is the first time I have ever noticed it doing this and there is no check engine light either. If you need to know it's a '91 hb with a d15 block and y8 head. Any Ideas? Thanks
1991hb is offline   Reply With Quote
Old 10-15-2006, 11:19 AM   #2
I made the millionth post
hosmer's Avatar
Ride:  03 350z, 03 CL-S, 02 Excursion, 91 CRX Si, 86 CRX Si
Rep Power: 58 hosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud of
Send a message via AIM to hosmer
temp sensor is shitting the bed maybe...?
Hold it fellas. I'm afraid you're just too darn loud. Next please. BRING THE NEXT GROUP PLEASE.
hosmer is offline   Reply With Quote
Old 10-22-2006, 08:12 AM   #3
VTEC CRX
BlueCrxNC's Avatar
Ride:  1990 Honda Civic Hatchback Std.
Rep Power: 0 BlueCrxNC is an unknown quantity at this point
Send a message via AIM to BlueCrxNC Send a message via MSN to BlueCrxNC Send a message via Yahoo to BlueCrxNC myspace
You'll never get a check engine light for the Temp Sensor. The cluster gauge uses a seperate sensor than the ECU. Either the sensor is going bad or you have a wiring issue (Corrosion causing partial wire break/loose connection, problem with gauge itself, etc.)
ED6 - 1990 Honda Civic Hatchback Std.
Swapping in soon:
JDM D15B VTEC, Chipped P28, Teg ZXi Tranny w/ HF 5th & OBX LSD
R.I.P. 11/2/2006->> 1989 Honda CRX HF - 253K
BlueCrxNC is offline   Reply With Quote
Forum Jump
Rotors utn Wheels / Suspension / Tires / Brakes 33 10-12-2004 02:24 PM
Talk about a strange day.... Airjockie Members' Lounge 16 09-14-2004 11:35 PM
Exhaust heat shields 92CHB General Tech and Maintenance 1 06-14-2004 09:45 AM
Prelude 1997 Heat problem... ovcrash General Tech and Maintenance 2 03-12-2004 11:45 AM
Computer Stuff eyesonlybob Members' Lounge 16 02-25-2003 09:58 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
