Help .. 91 Civic
Old 09-01-2009, 05:46 PM   #1
Greenhorn
Ride:  91 Civic HB
Rep Power: 0 freeride205 can only hope to improve
Send a message via MSN to freeride205
Default Help .. 91 Civic
hey guys i'm as new as it gets on the forum.
anyway i have a 91 civic that just does not start sometimes.
Like ill be driving around town no problems at all run into a store come out and it wont start ill wait anywhere from 10-30 mins sometimes more and then it will start.
Ive heard that its the distributor cap ive checked it ..swapped it still it does it
Anyway Thx Guys
freeride205 is offline   Reply With Quote
Old 09-01-2009, 06:05 PM   #2
AHHVTEC's Avatar
is the ecu/computer flashing any check lights
Old 09-01-2009, 06:10 PM   #3
Greenhorn
Ride:  91 Civic HB
Nope
no lights
Old 09-01-2009, 06:11 PM   #4
AHHVTEC's Avatar
well, does your main relay click and fuel pump hmm when its not wanting to start
Old 09-01-2009, 06:12 PM   #5
wwtdd?
95b16coupe's Avatar
Rep Power: 215 95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
check your grounds, battery cables, any wiring connections etc.
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic.
95b16coupe is offline   Reply With Quote
Old 09-01-2009, 10:35 PM   #6
Rep Power: 5 blasterman87 is on a distinguished road
sounds like a ground so me..
blasterman87 is offline   Reply With Quote
Old 09-01-2009, 11:46 PM   #7
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
i'm betting its either as simple as a loose ground, or it could be your main relay.
like AHhHvtak said does the relay click and fuel pump prime when you turn the key to run.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 09-02-2009, 03:31 AM   #8
Greenhorn
Ride:  91 Civic HB
if its a loose ground wouldnt it not turn over ?
It turns over..
It might be a fuel pump but i thought when a fuel pump goes, it goes.
Old 09-02-2009, 04:14 AM   #9
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
Next time it doesn't start try to hear if the fuel pump kicks on. I think its the main relay too. My CRX did the exact same thing and it turned out to be the relay.
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is online now   Reply With Quote
Old 09-02-2009, 02:54 PM   #10
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 21 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
It's more than likely your main relay. It will still try to turn over even if it is bad.. it just won't get fuel or spark. If you turn the car on to the on position you will hear it click and your CEL come on for a second then go off and you'll hear another click. If the CEL stays on and no clicks, bad relay.
PSN: Korax37
Korax is offline   Reply With Quote
Old 09-02-2009, 04:46 PM   #11
Greenhorn
Ride:  91 Civic HB
wheres the fuel pump at back or front
silly questions but im quite new to hondas
Old 09-02-2009, 04:47 PM   #12
Greenhorn
Ride:  91 Civic HB
ohh and another thing if the fuel pump doesnt go on its a main relay?
just to clarify
Old 09-02-2009, 04:53 PM   #13
Korax's Avatar
Umm.. in the back. If no fuel or spark then it's the relay. The pump could be bad too if it doesn't come on but it's more than likely your relay.
PSN: Korax37
Old 09-02-2009, 04:56 PM   #14
Greenhorn
Ride:  91 Civic HB
It just started after a couple mins of turning over and it smelt flooded does this eleminate the main relay or is that still a possiblity
Old 09-02-2009, 04:59 PM   #15
Korax's Avatar
The relay will work.. then not work.. then work.. etc, until it totally goes. I bet you had your car all closed up. Then you went outside to try to get it to start and opened the windows and the inside of the car got cooler. Does it start fine in the morning or evening?
Also, did you listen for it clicking at all when it wouldn't start? The relay is right behind the change tray. I'm sure if you tried to listen when it doesn't start you will either hear it or not.
PSN: Korax37
Old 09-02-2009, 05:08 PM   #16
Greenhorn
Ride:  91 Civic HB
yeah thats basicly what just just happend
my dad is having a hard time beliving its heat related because of where we live (northren canada) and its not that warm right now.
but it sounds like your right im gonna order that relay and see what happends
Thx alot for helping me ill get back to you when i get that switch and we will se what happends
