Greenhorn
last night i took my 91 ef hatch with a ls swap to the track and made one pass ran fine.
drove fine all the way back to staging shut the car and wouldnt start back up, cranking and cranking it finally fired over idled fine so i shut the car off. I figured since it had started it would be fine to drive home then. Wrong now the car wont start again, I have spark will fire on ether, fuel pump is working and i have a check engine light on i think. my question is how do i check the light on a swapped car? is there a special procedure? im new to the honda world dsm's are my thing but just done have the patience for them any more any help PLLLLLEEEEASSSE???? 91 hatch b18a? |
Ride: 88 Honda Civic HB
There should be a 2-pin connector either under the hood on the driver's side; has a yellow(IIRC) rubber cover on it. Jump that with a paperclip or something. Depending on the ECU, you'll have to either count the blinking CEL or the red light on the ECU. one long flash=10 and short ones =1, and you'd add them together. ie: 3 long and 3 short=code 33.
Greenhorn
i found a connecter under the hood that has like 5 wires going to it but couldnt find anything else. this is what i have found out car runs on ether, fuel pump is working, has fuel, the injectors are NOT pulsing, any ideas, has spark. cam sesnsor? crank sensor?
#5 |
Brutal Moderator
Ride: 97 Integra LS Coupe
A properly maintaned, stock engine Honda will typically run forever. Once you start in with the swaps and the modifications and the racing then who knows what the hell will happen...
#7 |
Ride: '92 Hatch si w/B16 (wannabe EG6)
Did you check under the dash for the service connector?
I have a 92-95 and mine is under my glove-box. Just like K2e2vin said, after you jump the plug, you check it like morris code. Your best option is to figure that out and let the ECU tell you whats up. What ECU? Motor? OBD converted? Stuff like that is needed for guys on here to be able to help more |
#10 |
If u have an obd 0 ecu from a 90-91 integra, the red light on the ecu will automatically blink if there is a hard code. If your car has been converted to obd 1, there might be a 2-pin plug on the conversion harness at the ecu.
#11 |
Ride: 91 civic hatch w/b16 and 91 civic hatch project car
The connector is under the passenger side dash its a 2 pin connector.I have an obd0 and an obd1 and the connector for both of them is under the dash on the passenger side.
#12 |
Greenhorn
found the connector thank you, also found a code 16 injectors, so i checked them and found they have 11 ohms but i have no resistor box would this be the reason why my ecu popped a fuse? the drew to much voltage. im only getting milli volts at the injector connector
#14 |
Brutal Moderator
Yes. I fail to see how that negates what I said...
| Honda : Civic HATCH 1993 HONDA CIVIC HATCH EG FULL GSR SWAP JDM VTEC CLEAN! | RSS-Bot | Auctions | 0 | 02-20-2009 12:03 PM |
| Honda : Civic DX HATCH EK HATCH W/B18C1 SWAP!! TODA, MUGEN, SKUNK 2, TYPE R | RSS-Bot | Auctions | 0 | 12-27-2007 08:43 PM |
| WTT my Allmotor LSVTEC hatch for eg coupe or hatch | david_jones001 | Vehicles: For Sale/Trade/Wanted | 5 | 04-24-2005 08:16 PM |
| ls turbo hatch vs itr hatch | b18hatch9 | Auto Multi-Media | 0 | 12-27-2004 01:48 AM |
