HELP!!! new too engine swaps
Old 10-21-2008, 09:30 AM   #1
dohcness44 is on a distinguished road
Default HELP!!! new too engine swaps
so i have a 90 crx. just did the engine swap in it... so i have a b16a block with ctr pistons. block was milled .002, also have a gsr head with gsr cams and intake manifold. ....... car starts up great but has a rough idle, sounds like miss fire. spark and fuel is great. when i pulled the plugs they are nearly dripping with fuel.. i have NGK-R spark plugs gapped at .035. if i start to get on it on the streets it has no balls at all. timing is at 16. no stutttering as im driving just doesnt feel like its at its most potensual... any suggestions???? also what Compression ratio do u guys think i have???
dohcness44 is offline   Reply With Quote
Old 10-21-2008, 10:46 AM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
you only need to post this once..
http://www.zealautowerks.com/
eg6sir is offline   Reply With Quote
Old 10-21-2008, 10:50 AM   #3
Führer Mod
eg6sir's Avatar
Ride:  Le Car
after plugging in what info you have given it looks like you're around 12.3:1 compression.. you're gonna need a kickass tune for it to run right on pump gas
Old 10-21-2008, 11:00 AM   #4
i have a spoon chiped obd0 ecu think i need more??
Old 10-21-2008, 11:27 AM   #5
Führer Mod
eg6sir's Avatar
Ride:  Le Car
is it a cheap eBay Spoon chip (most likely).. if so, ditch that garbage and go get tuned by an actual person.. not some premade chip that just dumps a ton of fuel into the motor... thats why it doesnt run the way it should
Old 10-21-2008, 11:48 AM   #6
ha ha ha ya i had money at the time just thought id try it..... i put the same computer in a stock b16 crx and it ran like a raped ape... i aslo tryed putting a stock pr3 ecu in and its the same???
i just checked the ecu now and im throwing 5 and 7... i know what 7 is witch is the tp sensor would that effect performance or just the idel???
Old 10-21-2008, 11:56 AM   #7
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
reikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
as eg6 said...your lack of a tune on a 12:1 comp engine is causing your problem. No matter how that ecu ran a stock b16...its gonna suck on yours.
reikoshea is online now   Reply With Quote
Old 10-21-2008, 06:38 PM   #8
^^ Likes Bewbies
George777's Avatar
Ride:  Rex, Yamaha Virago, CB900F Supersport
George777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
George777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
I think they are hinting that you need a GOOD tune from a REPUTABLE shop...
George777 is offline   Reply With Quote
engine swaps thiebert Engine Building 8 09-29-2009 03:23 PM
new at the engine swaps bankz0185 Accord 12 04-11-2008 03:09 PM
Engine swaps 93civicracer Engine Building 3 05-16-2007 08:33 PM
