help with stuck bolt
Old 07-26-2009, 01:18 PM   #1
91_stylin_civic's Avatar
Ride:  2008 honda civic SI,91 civic hatch w/b16 and 91 civic hatch project car
91_stylin_civic has a spectacular aura about91_stylin_civic has a spectacular aura about
Default help with stuck bolt
The right front lower control arm bolt that holds the arm to the sub-frame. The bolt will spin but the metal insert for the bushing is stuck on the bolt.When you try to take it out it just pulls apart the opening were the control arm goes into. I was going to cut the bolt on both ends and cut the welded nut off the back side of the frame. If anyone has any other ideas or has come across this before i am will to try it. I only have a propane torch to use and it will not get hot enough. Any help would be great thanks
91_stylin_civic is offline   Reply With Quote
Old 07-29-2009, 06:29 PM   #2
Ride:  90 crx w/zc dohc
Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
can you post pics of the problem bolt?
Fernpatch is offline   Reply With Quote
Old 07-29-2009, 07:01 PM   #3
I can try tomorrow its the inner most bolt on the front lower control arms. The bushing sleeve is the problem. Its rusted to the bolts and broke free from the bushing.
Old 07-29-2009, 11:48 PM   #4
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
myspace  FaceBook
Very precise torch work is your best bet.
We are stuck capricefrk013 HYBRID -> ED-EF / DA 32 08-15-2008 09:26 AM
Idol gets stuck / Gas peddle gets stuck GQMarques Civic and CRX - EF 13 11-02-2007 06:58 AM
Im stuck don't know what to do next BKKloppenborg Integra 0 06-03-2007 03:19 PM
%$**&^ im stuck racintweek HYBRID -> ED-EF / DA 7 06-13-2004 11:29 PM
stuck bolt jiahanhao General Tech and Maintenance 13 12-02-2003 12:12 AM
