Honda crx engine swap please help!
Old 09-07-2006, 03:47 PM   #1
Ride:  I drive a 2003 volkswagen GTI 1.8T
Rep Power: 7 doubleeightynines is on a distinguished road
Default Honda crx engine swap please help!
I have 2 1989 honda crx's one is an HF model and the other is a Si model. My si has the stock engine (which is only running on 3 cylinders)and the HF has a d16z6 (which has a radiator but it has no hoses). My original plans were to part out the HF and get money to save up for a b20 vtec which i would put into the Si. Whoever swapped the d16z6 into the hf did not put the right axles in it and it has no radiator hoses. I was wondering if i would be able to swap the d16z6 into the Si or would i have to buy other accesories such as axles or engine mounts. Someone please help me out what all would i need to complete this swap?!
doubleeightynines is offline   Reply With Quote
Old 09-07-2006, 06:03 PM   #2
Rep Power: 0 b18c1civic97 has a little shameless behaviour in the past
Send a message via AIM to b18c1civic97
swap it in, you can use the a6 axles, and you should be able to use stock radiator hoses. use the mounts that they used in the other crx for the motor.
b18c1civic97 is offline   Reply With Quote
Old 09-07-2006, 06:43 PM   #3
1991 crx si b16a vtec
Ride:  1991 honda sir b16a
Rep Power: 0 rziepke79 is on a distinguished road
does any one have the vacuum diagrams for a b16a in to a crx ?
rziepke79 is offline   Reply With Quote
Old 09-07-2006, 06:46 PM   #4
http://i25.photobucket.com/albums/c9...9/IMG_1503.jpg
Old 09-07-2006, 06:51 PM   #5
So the stock Si axles are compatable with the d16z6? I also don't have the vtech hooked up on the d16z6 because i don't have an ecu. Where would be the best place to get an ecu for this engine and which ecu do i need?
Old 09-07-2006, 06:56 PM   #6
the ecu you need is a p28 delsol.
go here
eBay Motors: p28 d16z6 virgin ecu del sol civic (item 140025889957 end time Sep-11-06 16:27:02 PDT)
Old 09-08-2006, 12:02 AM   #7
thanks
Engine swap t2phat Prelude 3 09-05-2006 10:32 PM
honda engine swap 1992 civic vx civic976 General Tech and Maintenance 1 08-06-2006 04:09 PM
ZC swap info pissedoffsol Swap Articles 2 07-06-2006 11:46 AM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
98 Honda Civic Ex Sedan H22 Engine Swap termtrip HYBRID -> EG-EK / DC 0 06-22-2003 01:38 PM
