How To: Make your gauge cluster brighter and clearer.
Old 09-07-2006, 06:37 PM   #1
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Default How To: Make your gauge cluster brighter and clearer.
Hey everyone, as you can see from my sig, I've recently been uploading some of my personal write-ups on different things regarding mostly EF's.
Heres my How To on making those gauge cluster lights really shine. Unfortunatly enough, and I'm really sorry, my motor is out of town getting built, so I don't have any before and after pics. But please be assured, it looks MUCH brighter and clearer.
Lets get to it.
You'll need:
-Small screwdriver. the screws are phillips head, but if it's small enough you can use a Flat head.
(Thats it!)
1. Start by locating the 4 screws that hold the gauge cluster cover on.
2. Remove them-
As for these two, just pop the little covers off and unscrew them.
3. As you start to pull the gauge cluster cover off, you'll feel some tension. Don't yank on it. Just look back behind it and you'll notice that your Hazard switch, Light dimmer, and rear defroster switches(if it's an SI) are holding it. Just unplug them and it will come right out.
4. On top of the gauge cluster you will find a small white plastic strip, the bulb housing. Unscrew the 2 screws holding it down and lift it up.
5. With this up, you'll see a reddish colored light defuser. Remove it. As you can see, that light defuser does a lot more than just turn the light the color orange. it actually blocks the majority of the light from the bulbs.
And thats all!
If you want color in your cluster, take a piece of plastic, whatever color you want, and cut it to size and put it where the OEM piece was.
Like I mentioned before, check my sig for other How To's, and as always, Comments are welcome.
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-29-2006, 05:30 AM   #2
any before or after shots?
90 Integra Sedan
B20V 225 / 153
Old 10-29-2006, 07:59 PM   #3
Andrew's Avatar
Ride:  1991 CRX Si
There were a couple great pics posted up on H-T a while back.
Let me see if I can find them(it might be later tomorrow before I can get to it though)
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-11-2006, 12:43 PM   #4
Rep Power: 7 NightCat is on a distinguished road
I wonder if you could do the following,
Cut a piece of plexiglass to the same size as the stock light difuser, then cut inside it to which you have a rectangle with no middle, then put a colored saran wrap over it and shove it back it.
it shouldn't defuse too much light cause of it's thinness however, it should give you the color you want.
NightCat is offline   Reply With Quote
Old 11-12-2006, 06:53 PM   #5
I provide inspiration!
89crxzc's Avatar
Ride:  crx si w/zc swap, 96 slammed accord, 06 toaster
Rep Power: 28 89crxzc is a name known to all89crxzc is a name known to all89crxzc is a name known to all89crxzc is a name known to all89crxzc is a name known to all
Send a message via Yahoo to 89crxzc myspace
thanks, i was trying to figure out how to get my gauge cluster brighter.
http://hondaswap.com/civic-crx-ef/crx-build-89168/
MY BUILD ^^^^^^^ updated 11/09/2007 new pics!
89% finished...........maybe.
89crxzc is offline   Reply With Quote
Old 11-12-2006, 07:27 PM   #6
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 366 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
hmm.. i think i'll try and make mine amber on my EG.. i'll figure it out
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 11-12-2006, 08:26 PM   #7
Andrew's Avatar
Ride:  1991 CRX Si
I've seen people do that, and it works great!
Go for it, and remember to take pics!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-12-2006, 10:17 PM   #8
98DoHcWarrior's Avatar
Rep Power: 12 98DoHcWarrior is off the scale
Hey man, this is a great Thread. Good Work...
98DoHcWarrior is offline   Reply With Quote
Old 11-13-2006, 08:08 AM   #9
Andrew's Avatar
Ride:  1991 CRX Si
Thx
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-17-2006, 05:18 PM   #10
Rep Power: 8 cor-e is on a distinguished road
Good stuff. I'll be doing that to my car. I love DIY (cuz I'm BROKE!).
cor-e is offline   Reply With Quote
Old 11-19-2006, 12:10 AM   #11
2 SLOW CREW
fasterimage's Avatar
Ride:  88 Hatch and a harley
Rep Power: 8 fasterimage is on a distinguished road
Send a message via AIM to fasterimage
Great write-up!! definetly will be doing that...Thank you
2 Slow Crew Racing
88 Civic Hatch- TURBO H22 swap
fasterimage is offline   Reply With Quote
Old 11-20-2006, 08:03 AM   #12
Andrew's Avatar
Ride:  1991 CRX Si
Ur welcome
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-11-2007, 05:39 PM   #13
Ride:  EF9
Rep Power: 6 Alpine is on a distinguished road
Send a message via AIM to Alpine myspace
I did it on my car. How much trouble did the dimmer plug give you? I couldn't get it out so I just lowered my wheel and moved it. I love it though and eventually will make it blue.
Alpine is offline   Reply With Quote
Old 01-11-2007, 06:00 PM   #14
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Amber FTW!!
XGT: cEElint
Old 01-11-2007, 06:11 PM   #15
Ride:  EF9
What did you do to make it amber?
Old 01-11-2007, 06:15 PM   #16
Führer Mod
eg6sir's Avatar
Ride:  Le Car
for my EG cluster, i just bought amber bulbs and replaced the others with them
XGT: cEElint
Old 01-11-2007, 06:31 PM   #17
Ride:  EF9
Nice. Where did you get the bulbs?
Old 01-11-2007, 06:35 PM   #18
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Autozone, but i've heard you can just scratch the blue thing off the bulbs that are in the cluster and color them with a red sharpie and it gives it a darker amber color..
XGT: cEElint
Old 08-28-2007, 11:39 PM   #19
Sonnova Bitch!
daveholiday's Avatar
Ride:  2006 GSX-R 600, 2003 Santa Fe GLS
Rep Power: 44 daveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud of
Send a message via AIM to daveholiday  FaceBook
I know this thread was last active more than 7 months ago, but just for anyone reading this and thinking about doing it, it's the shit.
this is during the day too
daveholiday is offline   Reply With Quote
Old 08-28-2007, 11:57 PM   #20
Yeah
EF9_Hatch's Avatar
Rep Power: 57 EF9_Hatch has a reputation beyond repute
EF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond repute
Send a message via AIM to EF9_Hatch myspace
wow i really want to do that now lol...i want green ones...anyone know where u can get green saran wrap lol? is it the same steps in an ef?
"It's not what you drive, but how you drive it."
XBL Gamertag= W0BBnIT <---- 0 is a Zero
EF9_Hatch is offline   Reply With Quote
Old 08-29-2007, 03:33 AM   #21
t.marie
LSacuragirl90's Avatar
Ride:  1990 Acura Integra LS-sold it but i want another one
Rep Power: 17 LSacuragirl90 is a glorious beacon of lightLSacuragirl90 is a glorious beacon of lightLSacuragirl90 is a glorious beacon of lightLSacuragirl90 is a glorious beacon of lightLSacuragirl90 is a glorious beacon of light
Send a message via AIM to LSacuragirl90 myspace  FaceBook
well this is off topic but i like the steering wheel.
get like you? Hell no, GET LIKE ME!!
LSacuragirl90 is offline   Reply With Quote
Old 08-29-2007, 07:47 AM   #22
Andrew's Avatar
Ride:  1991 CRX Si
Just use Green LED's.
Check my sig for a write-up on installing an aftermarket wheel.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-29-2007, 10:35 AM   #23
Yeah
EF9_Hatch's Avatar
Good Idea! Now where to find Green LED's that will work with that?
Old 08-29-2007, 11:23 AM   #24
Andrew's Avatar
Ride:  1991 CRX Si
First find out which bulbs you need:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Then buy LED's instead of halogens...
http://www.superbrightleds.com/cgi-b....12857&next=50
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-29-2007, 12:25 PM   #25
Yeah
EF9_Hatch's Avatar
Cool Thanks man! Definetly have to do this next time i get a chance!
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
