i need help smoken bad
Old 03-29-2008, 02:04 AM   #1
autox 89 dx's Avatar
Ride:  91 SI SOHC ZC mini me
Rep Power: 7 autox 89 dx will become famous soon enough
Unhappy i need help smoken bad
ok i get in my car tonite and it started to idle ruff.I let it sit for about 5 min.because it was fuckn freezen and the miss went away then i got on the freeway and it started missing then started to get hot but not to bad. When i got home it was really fuff so i checked the plugs and wires and found the plug was soaked on the #3 cylinder so i cleaned it up and put another plug in and now its burning hella oil and smoking really bad. What could this be maybe a broken ring or maybe a bent valve?
autox 89 dx is offline   Reply With Quote
Old 03-29-2008, 04:14 AM   #2
Ride:  91 integra with ls/vtec...
Rep Power: 10 ls/vtechatch91 is on a distinguished road
get a valve cover kit.. sounds like ur tube seals are bad on the valve cover.. try that...
ls/vtechatch91 is offline   Reply With Quote
Old 03-29-2008, 05:36 AM   #3
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
yeah that's a cheap easy attempt. i second that gasket replacement.
if you suspect the valve train is bent, or anything with the block, try a compression check. should be free.
Old 03-29-2008, 05:47 AM   #4
but if it was a bent valve u would hear it tho?? am i right... i'd do a compression check like YBLEGAL said. was the oil inside the spark plug whole???
Old 03-30-2008, 07:23 PM   #5
it was my head gasket the plug was loose for some reason and thats how the oil got there.Today i was messin with it and it smells like coolant and the smoke is more like steam checked the plug and its all wet from coolant
Old 03-30-2008, 07:45 PM   #6
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 215 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
^^^Yep white smoke is head gasket. If it was just burning oil it wont overheat like you said it did. And it was missing because it was eating coolant. Have the head sent out and checked for cracks and milled down in case it warped, which is usally the reason a head gasket goes, get a new head gasket and head bolts, DO NOT use the old ones, the bolts are torque to yeild and if you re-use them youll have the same problem again, and make sure you follow the torque sequence.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 03-31-2008, 01:22 AM   #7
Hates Cunts!
Aleaf.CRX's Avatar
Rep Power: 72 Aleaf.CRX has a reputation beyond repute
Aleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond repute
I was gonna say the headgasket.... happened to me once.
Aleaf.CRX is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
