I need someone who knows something about a 91 civic jdm
Old 10-07-2009, 05:27 PM   #1
Rep Power: 1 intheearlyhours is on a distinguished road
Default I need someone who knows something about a 91 civic jdm
Ok please read all of this before you post reply.
Ok i have a 1991 Honda Civic (not CRX) Jdm Z/C DOHC. My problem is that when i have the number 1 cylinder plugged in as i should it backfires through what sounds like the exhaust manifold. I have replaced the Dizzy about 6 months ago i have new plugs and wires, i checked the timing 3 times (ITS RIGHT). Someone once told me it could be a number 1 cylinder sensor or something, but than someone else said that they NEVER go bad. When i unplug the injector or just pull the wire from the number 1 cylinder it does not backfire just runs slow. and heres the thing. If i run it on 3 cylinders for about 2 days and than plug the number 1 back in it wont backfire for about 2 hours of driving. Please Please Please help me im so sick of this car right now.
Hit me up on my email also brandonniblock@yahoo.com or my AIM- mrbangbangsir
p.s. this is not a new swap i have been driving it for about a year or longer
intheearlyhours is offline   Reply With Quote
Old 10-07-2009, 06:39 PM   #2
jlicrx's Avatar
did this problem start when you changed plugs and wires? what kind of plugs and wires do you have? anything other than NGK plugs and OEM wires will cause problems
ZCspeed Racing
Old 10-07-2009, 06:58 PM   #3
i changed the plugs and wires thinking it would fix the problem. So its not the plugs
Old 10-07-2009, 07:12 PM   #4
jlicrx's Avatar
have you checked the fuel injector on the number 1 cylinder? unplug the connector - set the ohm meter to the lowest setting (200?) - measure resistance between the 2 terminals on the injector itself - should be 1.5 to 2.5 ohms - if not, the injector is bad
ZCspeed Racing
Old 10-07-2009, 07:16 PM   #5
Ok i did it with the car off and it did nothing and with the car on i got anywhere from 2.0 up tp 4.0 on the setting of 200OHMs
Old 10-07-2009, 07:35 PM   #6
Wait when you say the injector itself do you mean the plug that i pull out of it or something else??? i tested the plug
Old 10-07-2009, 07:50 PM   #7
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
you test power coming from the plug..and it sounds to me like your is F-ed up.
dumping too much fuel into cylinder 1...
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-07-2009, 07:58 PM   #8
Ok can you guys do me a favor and find how to check the injector from like amanual
Old 10-07-2009, 09:03 PM   #9
jlicrx's Avatar
ZCspeed Racing
Old 10-07-2009, 09:06 PM   #10
i really dont think its the injector
Old 10-07-2009, 09:09 PM   #11
my check engine never comes on but my ECU flashes code 9 and thats it
Old 10-08-2009, 09:52 AM   #12
bump
Old 10-08-2009, 07:07 PM   #13
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
CYP Sensor. Open up your dizzy. The sensor is inside your distributor. try probing pin b11 to the orange wire on the distributor and pin b12 to the white wire on your distributor. if it has continuity your fine this will just make sure the wiring is in good shape. if it isnt fix the wiring otherwise you will need a new distributor
Please direct your questions in the following format.
1) Did I search it on Google?
2) Did I use the search function in the TOP RIGHT AREA of this page?
3) Refer to Step 1 and 2.
If that doesn't work, then feel free to post.
RoughKnight is offline   Reply With Quote
Old 10-09-2009, 10:39 AM   #14
jlicrx's Avatar
the CYP sensor is not inside the distributor on the DOHC ZC - it is on the end of the exhaust camshaft and ECU pins are C1 and C2
Cylinder Position Sensor????
ZCspeed Racing
Old 10-09-2009, 12:05 PM   #15
Christmas Car
^ thanks for correcting me!
Old 10-09-2009, 01:26 PM   #16
Lol ok give me something else guys
Old 10-09-2009, 01:41 PM   #17
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
did you check the injector?
GOOD FAST CHEAP,
Old 10-09-2009, 08:59 PM   #18
not yet it really doesnt make sense for it to be that. or does it? I mean the problem i have is backfiring with number 1 cyl on. I also need to buy a new ohm reader mine broke.
