Identifying my CRX???
Old 10-18-2009, 08:05 PM   #26
Sofast is on a distinguished road
I thought about going back to grap the sunroof equip, and other items of value
Sofast is offline   Reply With Quote
Old 10-19-2009, 06:29 PM   #27
Well I wired everything up successfully. Then realized I have a bad pcm. The crank angle circuit in the pcm is crap. I verified the dizzy with a resistance of 380 (350-550 spec) Then I verified the circuit from C3 and C4 to the dizzy @380. And the pcm @ 800. Looks like its crap. Dang! Now I have to find another one.
Old 10-19-2009, 07:45 PM   #28
d16z6si is on a distinguished road
what pcm are you trying to run i might have an extra one
d16z6si is offline   Reply With Quote
Old 10-20-2009, 10:52 AM   #29
now its a 91
Ride:  91 civic dx hb with si harness and jdm d15b
89hatchd15b is on a distinguished road
Send a message via AIM to 89hatchd15b
I have one for a 89 si..... if you live in socal we could test it and see.
89hatchd15b is offline   Reply With Quote
Old 10-20-2009, 07:27 PM   #30
I got it worked out. I pulled a retard move. Instead of removing the pm5, I left it sit on the floorboard. I put the pm6 on the pass seat. When it came time to plug the pm6 in, I grapped the pm5 by mistake. After pulling my hair out trying to figure out what went wrong I went home. I came back the next day and realized what I did wrong. The only problem I have now is the idle. Past idle it runs great. @ idle it dies. The only code I have is TA sensor issue. I dont think thats my problem. What do you all think
Old 10-20-2009, 08:26 PM   #31
now its a 91
I have never had a ta code but I think that an intake air temp sensor might cause it to die at idle. I say replace it but someone else might have some experience with bad tas.
identifying crx flywheel AHHVTEC Civic and CRX - EF 4 09-15-2009 11:25 AM
Need help identifying my engine. John89 Civic and CRX - EF 20 10-03-2008 11:25 AM
Identifying an ITR head 92tegGP General Tech and Maintenance 0 02-21-2008 10:14 PM
ECU needs identifying awptickes Civic and del Sol - EG and EK 4 08-30-2007 10:19 AM
Identifying Zc mattcalica HYBRID -> EG-EK / DC 7 01-31-2003 06:47 PM
