ignition switch blew a fuse? No dash lights
Old 10-25-2007, 04:21 AM   #1
Rep Power: 6 Speed Box is on a distinguished road
Default ignition switch blew a fuse? No dash lights
I had problems starting by civic and replaced alot of parts. Searched and found that ignition switch could be one of the reasons.
Ok I got a new ignition switch from a dealer and the bitch was in the on position when i got it and put it in. I thought that I put it in wrong and started to turn it the other way, then small spark happened.
Now my dash lights don't even go on and car just beeps when the key is in. When you turn the key its as if battery is dead nothing happens. And battery is brand spanking new.
Now I can't even find out if ignition switch will help my car start. I checked all fuses.
Speed Box is offline   Reply With Quote
Old 10-25-2007, 04:34 PM   #2
Fixed.
50A fuse under hood and 10A fuse under dash in the wrong spot.
help! no dash lights or turn signals SI_nister Car Audio / Security / Electronic Accessories 42 03-18-2008 12:11 PM
will a 97 civic ignition switch fit 93 civic? facepants Civic and del Sol - EG and EK 0 10-20-2007 12:56 AM
94 Accord Dash Lights Prowler Accord 3 09-07-2006 01:36 PM
fiberglassing a dash webink_EK9 Body / Exterior / Interior / Cosmetics 18 03-28-2004 02:22 AM
Ignition Switch? JToolz HYBRID -> EG-EK / DC 6 02-16-2004 01:22 AM
