ilde speed adjustment .
Old 08-05-2008, 09:01 PM   #1
Rep Power: 0 ap731i is on a distinguished road
Default ilde speed adjustment .
just changed timing belt on 95 civic ilde running very low. tried to adjust idle screw with plug off no change.also check with timing light on red mark. distrib cap already max to the right.
ap731i is offline   Reply With Quote
Old 08-05-2008, 09:30 PM   #2
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 16 t3t4delsol is a jewel in the rought3t4delsol is a jewel in the rought3t4delsol is a jewel in the rought3t4delsol is a jewel in the rough
check your timing, its probably needs advanced a couple of degrees
t3t4delsol is offline   Reply With Quote
Old 08-12-2008, 08:33 PM   #3
would that be three teeth on the cam.
Old 08-12-2008, 08:44 PM   #4
t3t4delsol's Avatar
set the pully and the cam gear to top dead center, then advance the dizzy from there to advance the timing
Old 09-02-2008, 08:30 PM   #5
with car running i notice water dripping from tail pipe
Old 09-10-2008, 11:17 PM   #6
I still know everything
caboose's Avatar
Ride:  89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
Rep Power: 18 caboose is a name known to allcaboose is a name known to allcaboose is a name known to allcaboose is a name known to allcaboose is a name known to all
Water can drip from the tail pipe. It's typically condensation or a byproduct of the cat.
When you set your timing, I believe that you have to jumper the plug near the driver's motor mount. You shouldn't have to change the cam timing. Check the ignition timing again with a light. If you can't turn the distributor far enough, then double check to see that you have the timing belt right, and that it's not off a tooth.
Also when you are adjusting the idle, you are turning the little brass screw on the throttle body right?
Formerly the.original.kermit
Back from the dead...
twice
I NEED PARTS!!!
http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066
Check out my progress...
http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/
caboose is offline   Reply With Quote
Old 09-16-2008, 09:37 PM   #7
when you say off by tooth do you mean the r.r the belt or turn the crank.
Old 09-16-2008, 10:46 PM   #8
caboose's Avatar
Meaning that the cam is off one tooth. Put at TDC and see if all your marks line up.
twice
I NEED PARTS!!!
clutch adjustment del-sol sir General Tech and Maintenance 3 12-12-2006 05:47 PM
Valve Adjustment Help HatchSpeeD General Tech and Maintenance 14 07-04-2005 01:31 AM
Valve adjustment Battle Pope General Tech and Maintenance 5 01-23-2005 02:00 AM
headlight adjustment on ek toyarmy General Tech and Maintenance 1 08-15-2003 02:02 PM
Ilde Problem jaydemdc2 General Tech and Maintenance 3 06-11-2003 04:16 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
