Injectors
Old 03-10-2008, 12:42 AM   #1
Rep Power: 0 kevinbout is on a distinguished road
Default Injectors
Dsm 450 injectors in a d15b7?
Will they even fit?
Will they go in without much effort?
Benifits/ bad stuff.
I don't really have much of a clue when it comes to injectors so go easy on me!.
kevinbout is offline   Reply With Quote
Old 03-10-2008, 03:48 AM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 89 K2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud of
Send a message via AIM to K2e2vin
Yes they fit. You might have to swap connectors and/or use your stock injector o-rings. You just need to run a resistor box with them(or just solder in 10-ohm resistors on the positive wires to the injectors).
Only reason to upgrade to those is if you go turbo. Otherwise, they're a waste.
1988 Honda Civic STD-more mods than I want to list
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 03-10-2008, 09:27 AM   #3
Alright thanks!
So if i install them i wont feel any differance? just burning more gas?.
Are there any explanation threads on injectors or fuel rails?
The more knowledge i have the better.
Old 03-10-2008, 10:18 AM   #4
Honda FTW!
Ride:  88 crx hf
Rep Power: 4 LightWeightChamp is on a distinguished road
You will need to tune for bigger injectors also.
LightWeightChamp is offline   Reply With Quote
Old 03-10-2008, 11:52 AM   #5
K2e2vin's Avatar
You'll feel a difference if you just pop them in; the car will feel slower.
RIP
Old 03-11-2008, 10:11 AM   #6
Well there would be no "just popping them in" i'd put them in as proporly as possible. but it doesn't matter i'm not going to bother with them.
Old 03-20-2008, 11:29 PM   #7
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 3 monotech909 is on a distinguished road
definately not the way to go. Stick to the 240cc stock injectors and specially for daily driven whip!
Get a fuel pressure regulator and 255 Lph Walbro fuel pump if looking for better response no need to change the injectors unless you plan on going turbo or SC.
monotech909 is offline   Reply With Quote
Forum Jump
H22 Injectors TeamUrbanChaos HYBRID -> BA-BB /CA-CD 7 10-27-2008 12:11 AM
wich injectors Supadax General Tech and Maintenance 14 07-20-2005 10:45 PM
Peak / Hold VS Saturated Injectors pissedoffsol General Tech Articles 2 04-18-2005 12:53 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
Saturated injectors from a 1999 Type R eroman HYBRID -> ED-EF / DA 6 05-29-2004 05:07 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
