Ride: white '91 crx hf and '04 Neon SRT-4
I just got my crx running after sitting for a very long time, when i fire it up it wants to idle a little high, then after warming up for a minute the idle jumps up and down between 1000 & 1500 rpm. i was thinking a vacuum leak or something ? The engine is a D16a6 if that helps any ...Any help would be greatly appreciated!
żUnKnOwN?
Ride: 91 CRX si
it sounds like you iacv or fast idle control valve
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX R.I.P BEN LEE2/24/08 we love and miss you R.I.P Rex 8/18/08 coolest dog ever!!! GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
thanks for the reply ill check them tomorrow, out of time today... on another post with the same problem someone thought it might be air in the coolant system..?? worth a try also .......
żUnKnOwN?
Ride: 91 CRX si
yep,,try bleeding it out
| idle jumping with a/c on. ok with a/c off | bannacrx | Civic and del Sol - EG and EK | 7 | 06-29-2008 03:13 PM |
| jumping rex | formby | Wheels / Suspension / Tires / Brakes | 5 | 07-06-2006 09:08 PM |
| h22a accord jumping idle | piening2150 | General Tech and Maintenance | 8 | 11-15-2005 03:45 PM |
| rpm nidle jumping | possessedimports | Engine Building | 9 | 09-28-2003 03:16 PM |
| Ecu Pin Jumping? | sprfreek | ECU's, Electronics, and Tuning | 12 | 02-17-2003 06:06 AM |
