knock sensor
Old 02-20-2009, 09:07 AM   #1
Greenhorn
Ride:  91 CRX D16 VTEC / 05 SRT-4 400HP
Rep Power: 0 BIGP4LIFE is on a distinguished road
Default knock sensor
im hookin up a d16 in my 91 crx and cant figure out where the knock sensor goes. where does it go and with that not bein hooked up would it cause it not to start?
BIGP4LIFE is offline   Reply With Quote
Old 02-20-2009, 10:19 AM   #2
jlicrx's Avatar
what kind of D16 do you have that has a knock sensor?
ZCspeed Racing
Old 02-20-2009, 03:40 PM   #3
Greenhorn
i have a d16 a6 bottom end with a d16 z6 head im switchin it from dpfi to mpfi and vtec and i cant find a knock sensor hook up but the jumper harness i bought for the swop is saying that i need to hook up a knock sensor so i didnt know where it would go or if i need to hook that wire up to somthin else to by pass or redirect the wire
Old 02-21-2009, 12:42 AM   #4
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
the a6 block does not have a knock sensor and i dont think it even has a place to install one. and unless you are running an obd2 ecu you don't need one.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 02-21-2009, 01:16 AM   #5
Greenhorn
yea i figured it out tonight and finally got it runnin thanks for yalls inputs
but i have another ? i got the car to run and the cam gear and belt side is in timing but the distrubtor side is not and where is it in timing and keeps the car running it wont bolt up to any of the ears so whts a solution to that? would it be safe to turn the cam gear so its a couple teeth back nd it work or will it be in the position to where the vales will be down when the piston is up and mess up the valves and motor?????
Old 02-21-2009, 01:53 AM   #6
mintoxik's Avatar
Ride:  93 civic of doom
Rep Power: 6 mintoxik is on a distinguished road
to see if your dizzy is right put your engine to TDC then the rotor should be pointing to the #1 sparkplug.
and if your dizzy won't bolt up did you get the z6 dizzy?
or maybe it is flipped 180 degrees?
mintoxik is offline   Reply With Quote
Old 02-21-2009, 04:56 AM   #7
Greenhorn
its a 42 u distributor, which is what i have read to be the right distibutor, and all the ears will bolt up, just not in the position that it needs to be for the car to run right it seems. and if you flip the distibutor gear 180 degrees it doesnt seem to fit into the head right so idk. any other suggestions to any other distibutor that i might need?
Old 02-22-2009, 01:12 AM   #8
mintoxik's Avatar
did you try and move the dizzy cause maybe ur IGN. timing is off
but you have the right dizzy and check to see if your sparkplug wires are in the right order
Old 02-22-2009, 01:18 PM   #9
Greenhorn
yea i have moved the dizzy and it is in timng but where it is now and in timing it wont bolt up to any of the ears on the head and all the plug wires are right so idk what to do ?????
WTB ASAP: b18c1 knock sensor or any b series knock sensor that will work asap!!! Hav tofasttoslowforyou Parts: For Sale/Trade/Wanted 0 11-05-2008 05:54 PM
Knock sensor Vetalik HYBRID -> EG-EK / DC 3 12-11-2003 12:32 PM
knock sensor skylineboy ECU's, Electronics, and Tuning 4 12-08-2003 11:24 PM
Knock Sensor Location B16 sirII 02 sensor Gooseguir HYBRID -> EG-EK / DC 1 10-26-2003 04:43 PM
B16a sirII Knock sensor O2 sensor Gooseguir HYBRID -> EG-EK / DC 3 10-25-2003 10:26 PM
