#1 | |
SOHC on this!!
Eventually I'm lowering my car.
I have '90 Integra rear discs on my '90 Civic Si. When I did the swap I used this page: ![]() In the blue writing it says every 1" I lower the car I have to add a washer. Can anyone verify this? I'm going to get an alignment when I'm finished so could they do this then? Thanks, Brad __________________
My mom thinks i'm cool
Ride: 91 sedan / 01 aprilia
yea , i lowered my 88 and all you have to do is add washers. it works
"Yaaaa Trick Yaaaaa!" 88 sedan stock with a flowmaster 40 series 2 3/4 pipe- rear ended somebody 88 hatch built b16- rolled doing120mph 90 hatch stock b16- pulled motor and sold shell now- stock 91 sedan |
Ride: 1990 Honda Civic DX "The Snackbox"
Or another way to do it is to just get a camber kit. It is more precise that way and you know for sure your camber and toe is going to be straight. Just put your camber kit on and take it to les schwab. I just had mine aligned last week. Just be sure to tell them you have a camber kit and your car is lowered.
#4 | |
SOHC on this!!
About how much is a camber kit?
#5 |
My name is Byron.
Ride: 89' DX Hatch w/B16
Just go with longer bolts and some washers, cheaper and works just the same.
^ (dont listen) Dont PM me with tech questions. I will not answer them. There is a hidden message here. "Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details." "In the dice game of life who gets the last roll?" |
#6 | |
SOHC on this!!
Makes sense, if I was to get a camber kit I would get it for the front anyway.
#7 |
The ebay camber kit works just fine. They are cheap and work great. It is a good idea to do at least the front so you can get the toe right too. My toe was off 4 degrees and I wore tires out in like 300 miles. It sucked.
| lowering?? | 92hprelude | Prelude | 10 | 05-13-2009 03:28 PM |
| Lowering 95 ex | old-noob | HYBRID -> EG-EK / DC | 2 | 10-08-2008 03:24 PM |
| Lowering Q.... | randerson165 | Wheels / Suspension / Tires / Brakes | 14 | 12-16-2003 03:30 AM |
| Lowering My Crx | biglee414 | Wheels / Suspension / Tires / Brakes | 14 | 05-21-2003 11:44 AM |
| Lowering | SaintJude | Wheels / Suspension / Tires / Brakes | 6 | 04-23-2003 02:49 AM |
