ls w vtech head???????
Old 10-03-2009, 02:20 PM   #1
Greenhorn
Rep Power: 0 91lsRex is on a distinguished road
Default ls w vtech head???????
I currently have a b18 b1 with some internal mods with a turbonetics 57 trim turbo makin about 225whp. Lookin for 300whp is a vtech head worth the money and the hassle if so which head would anyone recomend???????
91lsRex is offline   Reply With Quote
Old 10-03-2009, 04:00 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
your not going to make 75hp off a headswap..
what internal mods do you have first off??
and you can def. squeeze more hp out of your setup now..
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-03-2009, 04:06 PM   #3
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
you aren't going to get the 75hp, but you'll be damned close with a b16 head. It flows better and no matter how much people say vtec and turbo's suck, the numbers will prove all the nay sayers wrong EVERY TIME. Id imagine that if your car dyno'd at 225 on an LS, adding a better flowing head with more aggressive cams is probably going to net you some pretty impressive gains. At a minimum I'd guess you dyno again at 275.
Anime Informant
reikoshea is offline   Reply With Quote
Old 10-03-2009, 04:08 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
he can dyno right now and probably get 250...the gay bryan got 253 on an all stock turbo ls..
GOOD FAST CHEAP,
Old 10-03-2009, 04:14 PM   #5
HS Troll...And Mod
reikoshea's Avatar
myspace
maybe with a boost controller......i doubt the psi is lining up on that one.
Anime Informant
Old 10-03-2009, 04:28 PM   #6
Rep Power: 7 SuburbanNoize is a jewel in the roughSuburbanNoize is a jewel in the roughSuburbanNoize is a jewel in the roughSuburbanNoize is a jewel in the rough
On my brothers internally stock, b18b, straight LS, we made 270 HP, using a precision sc60. Now his set up is a fully built LS/Vtec and it makes way over 300 on only 10 pounds using a precision sc61. The head swap alone wont net you 75horses. But a head swap and a retune on more boost will get you there. The VTEC heads flow soo much better than an LS head.
SuburbanNoize is offline   Reply With Quote
Old 10-03-2009, 07:32 PM   #7
Greenhorn
internal mods... eagle rods,crower valve springs and titanium retainers, high boost mls head gasket and race engineering block guard. my shop says i have to get rid of my FMU {which was already in the car when i bought it} i dont even know what it is. that will free up more power. is this true????? by the way fully tuned at 5psi with hondata.
Old 10-03-2009, 07:37 PM   #8
Greenhorn
how much would this head swap cost about? im not a mechanic so shop prices please...
and vtech head off what? nobody answerd that question
Old 10-03-2009, 09:18 PM   #9
tabKola's Avatar
Ride:  civic ek 4 door
Rep Power: 5 tabKola is on a distinguished road
Off of a B16, B18C, B18C5, or a B18C1.
tabKola is offline   Reply With Quote
Old 10-03-2009, 11:43 PM   #10
Greenhorn
Default to rebuild or not to rebuild
i think my turbo seals are blown out thats why im smokin all the time. POS turbonetics. should i send back to rebuild for about 500.00 or get new one????
can anyone recomend a turbo for ls crx like to get 300whp.
Old 10-04-2009, 01:19 AM   #11
HS Troll...And Mod
reikoshea's Avatar
myspace
in a sense yes. they're telling you to get rid of it because its a shitty way to tune a car and a lot of times it ends with a ruined engine or ruined turbo (might explain the blown seals you also mentioned).
Anime Informant
Old 10-04-2009, 04:28 AM   #12
Dont Spend 500 bucks to rebuild a turbonetics turbo. For 500 bucks your 2/3 to 1/2 the price of a new turbo. The precision sc61 we run on out integra cost 750 but you find them online for anywhere from 750-1000 bucks, There was a used and in good condition gt30r on my other forum for 500 bucks the day after i bought the precision.
Old 10-04-2009, 10:06 AM   #13
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
wow tuned on 5psi..up the boost and run the right stuff and you will def. get better numbers..
also the best head would be from the gsr b18c1,because it doesnt raise compression like the type-r or b16..
GOOD FAST CHEAP,
Old 10-04-2009, 12:51 PM   #14
HS Troll...And Mod
reikoshea's Avatar
myspace
I think you might have that a bit backwards bro:
The GSR head increases compression more than the b16.
Also, the b16 gets better numbers on flow bench than the gsr head (stock v. stock), which makes it better for turbo apps. The design of the combustion chamber in the GSR head make it a better candidate for an NA motor.
Anime Informant
Old 10-04-2009, 01:30 PM   #15
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
you are correct..my head isnt on straight lol
GOOD FAST CHEAP,
Old 10-07-2009, 08:26 AM   #16
Ride:  i go to towers every friday wit my girl and to us 27 to race
Rep Power: 1 egfreak is on a distinguished road
Default b20b head
i would recommend putting a b20b head on your ls block but what head would you want to put on there
egfreak is offline   Reply With Quote
1996 civic swapped vtech head james.macisaac ECU's, Electronics, and Tuning 0 09-28-2008 12:00 PM
b20 cams...b18 head---VTECH INJEN78 Engine Building 6 05-26-2008 06:41 PM
d16z6 or y8 vtech head onto d15 block? fartknocker HYBRID -> ED-EF / DA 2 03-03-2004 06:10 PM
D16 vtech head on a D15 block weirdman77 HYBRID -> EG-EK / DC 1 09-29-2003 11:16 AM
Non Vtec to Vtech Head Swap blackdragon69 Engine Building 10 10-24-2002 04:25 AM
