Discuss Swap information, turbo installation, general Honda tech, ecu chipping, and tuning at HondaSwap.com
Would the main relay have something to do with my ecu throwing a fuel injector code? I just replaced my main injector in my DX but still getting a injector code. Any ideas?? Also every once in a while it wont start for about 5-10 key cycles and then it will fire right up.
universal logic protocol
Ride: 99 VW GTI 90 Civic Hatch 07 Jeep Compass
Cars with Dual Port Fuel Injection (DPFI) have two injectors a main one and an auxillary.
90 Civic Hatch 99 VW GTI <= BIG F'IN POS 07 Jeep Compass If you ever find anything I write usefull please leave rep. Rebuilding a Transmission http://www.the-whiterabbit.com |
Ride: 91 civic DX
The main relay on that year of a honda with dpfi controls the fuel pump along with sending power to the injectors. If you are having problems starting up the car then either replace the relay or if you have a helms manuall it will tell you how to test out that relay.
#5 |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
It is possible it's the main relay. Also check the resistance across the 2 leads of each fuel injector. I forget off hand what the resistance nominally should be, but haynes or helms or a chilton should say.
YBLEGAL.NET → Profile • Projects • Parts For Sale → Steel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal |
| Main Relay | gold-h22a | Prelude | 0 | 09-06-2007 08:15 AM |
| Main Relay vs Ecu Question | reckedracing | HYBRID -> ED-EF / DA | 10 | 05-25-2006 11:53 AM |
| what exactly does a main relay do? | civiclxb16 | HYBRID -> EG-EK / DC | 47 | 03-15-2005 08:29 AM |
| main relay | Scilingo | General Tech and Maintenance | 5 | 02-15-2005 10:44 AM |
| CRX MAIN RELAY AND FUEL RELAY | CReX123 | HYBRID -> ED-EF / DA | 4 | 07-30-2004 02:04 PM |
