Major delima
Old 01-01-2008, 01:02 AM   #1
Rep Power: 4 chaz_w16 is on a distinguished road
Default Major delima
Hey i put a LS non-vtec in my 89 civic hatch. i did all the wiring from fourthgenhatch.com. when i got it all done i started it. The car will bog out and backfire through the intake if i give it some gas but i can slowly go threw the first about 500 rpms then i can hammer on it and it revs fine. it threw codes 4 and 9 so i put a new distributer in it and that fixed the code problem but it still misfires. Does anyone got any ideas on this? I didnt take it apart since i took it out of the integra...
chaz_w16 is offline   Reply With Quote
Old 01-01-2008, 01:06 AM   #2
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 26 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Did you run your spark plug wires to the right plug, or outlet on the cap?
www.supremacyracing.com
801CRX is offline   Reply With Quote
Old 01-01-2008, 01:10 AM   #3
ya i got that all correct should be really close to in time.. i got a video on my phone...its just weird cuz it idles fine but if you give it gas it bogs and backfires threw the intake...you can take it slowly threw the first rpms and it will rev out just fine after that
Old 01-01-2008, 01:18 AM   #4
Got Rice?
801CRX's Avatar
Hmmmmmm its got to be something simple.
Double check your wiring, hell tripple check it. Most often people look straight to the big problems, and most often the most exspensive too. When all they needed to do was so small and cheap.
Just take your time and run through the steps very meticulously[is that spelled right_hum who cares]
Good luck
Old 01-01-2008, 01:22 AM   #5
oh trust me ive rewired it like four times to make sure it was all good lol...i might take it in to one of the honda shops around here and see what they say
Old 01-01-2008, 01:56 AM   #6
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 213 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
its sounds like your a tooth off on the timing..or your 180 degrees out on timing...how are the wires on the dizzy?
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 01-01-2008, 01:58 AM   #7
1--3--4--2...
Old 01-01-2008, 02:43 AM   #8
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Did you ever replace the spark plugs? Obviously they have to be fouled if its missing. You did change the distributor, so check your plugs. Replace them and make sure they are gapped to Honda's spec. Once that is done, IF it is still mis-firing, take all the plugs out and put a long straw into cylinder #1 or cylinder #4. Spin the crank until the pistons in cylinder #1 and #4 are at top dead center (TDC). The straw should be sticking up and out as high as it possibly can, just make sure the straw is actually ontop of the piston. once it is at TDC, take the distributor cap off and make sure the rotor is pointing right at the spot where the cylinder #1 plug wire is applied onto the distributor. Once that is correct, make sure your cam gear arrow is pointing directly up. If its dead on, than your timing isnt your problem.
Since there are no CEL's, than your sensors aren't the problem either(electrical). So what does that leave us with....? Could be a problem with the ecu... most likely not, but swap another ecu (stock for your engine/harness) and see how it works than.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 01-01-2008, 02:46 AM   #9
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
34
12 4321
front of car
thats how they should be
GOOD FAST CHEAP,
Old 01-01-2008, 02:49 AM   #10
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
180 degrees off on the timing, the engine would run like straight up ass. Timing is very crucial to an engines performance. If he is 180 degrees off, than his distributor will fire the cylinder at a completely wrong time causing pre-mature combustion which will build up more heat in the cylinders, and toast the plugs. ... It is possible that he is off by a few teeth, but not 180 degrees.
Old 01-01-2008, 02:51 AM   #11
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
bullshit..my car was 180 out and it ran like ass but didnt do anything to the plugs...
GOOD FAST CHEAP,
Old 01-01-2008, 02:54 AM   #12
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
How long did you drive your car with it off by 180 degrees? Not long I bet. My friends was off by 180 and his plugs were fouled out BAD in 5 days.
Old 01-01-2008, 02:56 AM   #13
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
the car wouldnt drive...everytime id go to put load on it, it would stall..wouldnt go over 2200...was very hesitant,and kept sputtering and bogging...
GOOD FAST CHEAP,
Old 01-01-2008, 02:56 AM   #14
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
What engine?
Old 01-01-2008, 02:57 AM   #15
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
My friends car would drive but break up hardcore (b16a2 engine), and was also hesitant but didnt stall.
Old 01-01-2008, 02:58 AM   #16
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
minime d16
GOOD FAST CHEAP,
Old 01-01-2008, 03:00 AM   #17
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
see you didnt really drive it. Mike (my friend), his car might not have been off by so much, I didnt do the work on it, one of his other retard friends did. But he corrected the timing and changed his plugs and was fine. He also lives 45 minutes from where I work so bringing it to my shop wouldnt have been the easiest for him to do.
Old 01-01-2008, 03:05 AM   #18
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
yea..it was prolly off a couple teeth or more...but def. not 180..
i had the car off 2 teeth and thats what fouled the plugs...
GOOD FAST CHEAP,
Old 01-01-2008, 03:09 AM   #19
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
excessive driving under those conditions will cause the plugs to foul over time. Determining the time is pretty much on how off the timing is and how much load you put on the engine under those conditions.
Old 01-01-2008, 03:10 AM   #20
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Thank god for USPS Priority Mail!!! My new pistons should be here by thursday hopefully.
Old 01-01-2008, 07:04 PM   #21
i checked the timing it all fine the only thing i can think of is that the LS ecu is crapped out...i hear the Si out of a 88-91 civic is one i should try for DPFI to MPFI?
Old 01-01-2008, 08:11 PM   #22
its the only vid i could get, kinda hard to hear cuz its in the shop...
MySpaceTV Videos: runs but with a problem by Chaz
Old 01-02-2008, 01:17 AM   #23
commander
Ride:  ek ,ef , ef , cbr 600rr
Rep Power: 0 commanderinstall is on a distinguished road
check tps sensor . i would stick with the b18 computer.
commanderinstall is offline   Reply With Quote
Old 01-02-2008, 02:19 AM   #24
code four keeps comin up and ive done everything to stop it but it still does....whats that TPS sensor and how do i check it?
Old 01-02-2008, 02:25 AM   #25
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 26 philyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the rough
tps sensor is the throttle position sensor as for how you check it I can't help you with that. It is on the backside of the throttle body, only reason I know is the h23a1 I bought had a broken tps.
philyphreak2127 is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
