#26 |
you get the BRAKE
do you know what code 4 means?
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#28 |
you get the BRAKE
Find out exactly what that code is. From there you can check the sensor that applies to the code being thrown and inspect it. Check for bad connections, corroded wires etc. If the wiring is fine, replace the sensor.
#30 |
commander
all u need is a volt meter, loose the two bolts on the tps . find the right voltage . and tighten it up. thier is a write up on how do it on honda swap . i had the same problem with one of my b18a , but i just put another throttle body on and it stop blog out . tps is vary important as i found out.
#31 |
you get the BRAKE
ok, let me just ask these questions right now..
1) year/make/model of the car? 2) engine code/engine harness used / ecu? __________________
#32 |
#34 |
you get the BRAKE
Did you make sure to plug the connectors for the sensors into the correct spots? I see some people mix up the sensor plugs. Check for that and also, remove all sensors and do a quick spray in them with brake cleaner, and clean it up and plug them all back up. Check all fuses in the relay and inside the car under the drivers side kick panel.
