This is a discussion on Mini Me help in the Civic and CRX - EF forum
iidk if this is right but are all the fuel injectors inject fuel at the same time and how do i set the time on this mini me like how ment degrees do i need to turn the adjustable cam gear and what not...
| | #1 |
| iidk if this is right but are all the fuel injectors inject fuel at the same time and how do i set the time on this mini me like how ment degrees do i need to turn the adjustable cam gear and what not |
| | #2 |
| no the injectors inject at diff times just like two pistons up two pistons down on the block when in motion how you set the timing this is how i do it and it never fails take sparkplug #1 out from the head,move the cam shaft to the nearest point in "UP" position if its hard to move or wont move then turn the crank a lil, when done stick your dipstick in the sparkplug #1 hole and turn crank till its at its very top position then you turn just a lil not even a bit but a lil and you set the block on time the head make sure the arrow for up is at the top slide in belt a whalaa............. |
Similar Threads | ||||
| Mini : Classic Mini Vtec Estate Classic mini estate vtec | RSS-Bot | Auctions | 0 | 09-24-2010 10:17 AM |
| Mini : Classic Mini 1973 AUSTIN MINI COOPER S SPORTSPACK VTEC JOHN COOPER | RSS-Bot | Auctions | 0 | 08-14-2009 02:36 PM |
| Mini : Classic Mini 1979 Classic Mini | RSS-Bot | Auctions | 0 | 12-01-2007 03:13 PM |
| mini-me done | boud92si | HYBRID -> EG-EK / DC | 0 | 09-10-2003 07:19 AM |
