Ride: 1991 civic hatch dx
I was looking online and I came across this article D16A6 to D16Z6 Conversion..."Mini-Me"
the one thing that I'm wondering is even though I've got a d15b2 but I'm doing a mpfi swap that would give it the si dizzy and I've already got a z6 intake mani, wouldn't that kind of make it like the a6? thanks |
#6 |
seeing that the z6 has a bore and stroke of 75 x 90 and the b2 has one of 75 x 84.5 how much would that change the compression because thats 5.5mm difference
#7 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
itll probably lower it a little bit..
but why dont you find a 1.6 block around ct? __________________
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#9 |
wow I was just looking on SolBlu's Helpful Del Sol Site and seeing that the d15b7 is pretty much the same as the b2, I used that as the block and it said that it should jack it up to 9.84:1 from 9.1:1 thats pretty good
#10 | ||
SOHC on this!!
#11 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
word i dunno if you wanna stick with th 15 then go ahead,but i feel the 1.6 have more support
#12 |
oh no the d16 defiantly has better support. But I did get some good news. I had to give me friend a ride home today but we stopped at his nephews house and he's get a 91 integra ls just sitting there, he also has an 89 integra that if I go a head gasket, a tune up, and a few little things for him, I can pretty much have the engine and tranny, and probably the axles, the bad news is that it's got a misfire in cylinder #1, but that could be anything
#13 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
so youll be getting what?
#14 |
I still may do a half assed mini me on this engine, but I'll get the 1.8 ls engine, tranny, and maybe the axles. Just for doing a head gasket, a tune up, and maybe a few other things.
#15 |
If I were you, I'd fix nephs' car, do a quick rebuild/re-ring to the LS, find some hotter cams and swap that in once you get all the parts together.
From what's said, you would have enough torque to keep you smiling even after you get to work/school. E __________________
"If you can read, thank a teacher" "If you can read it in English, thank a VET" |
#16 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
the ls is actually a pretty simple swap..and will give you more hp than doing the minime..get the ls and let us know if you need any help.
#18 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
how wouldnt it???? its a zc
#20 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
is the teg a standard???if so take everything..
motor,tranny,axles,ecu,you can even take the wiring harness..only thing that wouldnt work is mounts,and shift linkage,,but you should also take the rear mount bracket..its a necessity for this swap __________________
#22 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
obd0...yea take everything..you might be able to sell the mounts for a little bit of cash..depending what shape..but yea..you already have the whole swap there..except the linkage and mount kit..which the linkage you can actually cut and use..and the mounts you can get ebays for less than $100 shipped from ebay
#24 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
yea ef to bseries..
#25 |
Senior Citizen
Ride: 1991 civic sedan 1972 datsun 620
Off subject 89 teg-d16a1 does NOT fit ef IT does fit 84-87 civic aKa EW. The driver side mount is on the front of engine not on timming cover.The ZC was only offered in japan. ON subject nice find on the 91 teg that should be a fun ride
| another mini-me question | sevenhillsbilly | HYBRID -> ED-EF / DA | 2 | 03-26-2008 02:48 AM |
| mini me question | mi1av0ng | General Tech and Maintenance | 0 | 07-29-2007 09:34 PM |
| DX/STD to mini me ecu question | reckedracing | ECU's, Electronics, and Tuning | 4 | 05-25-2004 04:26 PM |
| mini me question! need help! | o0ohferrealz | HYBRID -> ED-EF / DA | 2 | 03-11-2004 10:08 PM |
| Mini Me Question | mrvanparys | HYBRID -> EG-EK / DC | 4 | 06-19-2003 01:30 AM |
