motor question
Old 03-23-2008, 02:01 PM   #1
8ballsin's Avatar
Ride:  1990 Honda CRX Si
Rep Power: 5 8ballsin is on a distinguished road
myspace
Default motor question
will any b series bolt right in a 1990 crx si with out modifications or new mounts
8ballsin is offline   Reply With Quote
Old 03-23-2008, 04:16 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
damn,you really need to search..
you need a mount kit... B-Series into EF
you will also need alot more than just mounts...search for my thread,,its called
LS ALREADY COVERED?
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 03-24-2008, 03:50 AM   #3
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 5 monotech909 is on a distinguished road
you need B series mounts or you can do it the ghetto way and relocate the mounting bracket but not recommended unless you know what you are doing. If you relocate the mounting brackets they have to be done right and reinforced. Just use Arizona Race mounts or Hasport mounts don't use those ghetto metal cheap mounts cause yeah they are cheaper but not worth it when dealing with a good engine swap.
monotech909 is offline   Reply With Quote
Old 03-31-2008, 03:48 AM   #4
honda builder by nature
wadocrx's Avatar
Ride:  Lexus GS400
Rep Power: 4 wadocrx is on a distinguished road
myspace
You need mounts,linkage,t-bracket, axles with jack shaft, ecu, and sew of other items to complete this. If you go on Hasports website they will tell you everything. In fact, my shop is so close to Hasport I could throw a rock and hit it! So if you need mounts and linkage e-mail me, I get good deals on them. I also have the t-bracket, jack shaft, and throttle cable needed to do this.
wados_n_az@yahoo.com
wadocrx is offline   Reply With Quote
