Greenhorn
Okay, i hate to bug you guys...but maybe someone here can help me out. So i bought a 91 civic si with a b16a obd0 swap. The idle hops up and down after a cold start up, it seems to not be operating at its best(performance wise), it failed emmissions, and vtec won't engage. The ecu was giving me a MAP sensor code so i replaced it because the car had all the symptoms of a faulty MAP sensor. The error code went away but it seems to run identically. Now the ECU is flashing 3 things; VTEC solenoid valve, knock sensor, and secondary o2 sensor. I noticed that if its giving you a code 2 (faulty secondary o2 sensor) it might be because of a faulty ecu, but i really don't think thats the problem. If anyone has had any similar experiences or suggestions of what the problem could be, i would greatly appreciate it.
Ride: '92 Hatch si w/B16 (wannabe EG6)
Check your wiring....if the swap was done....wiring for those parts seems to be the first place
I'd look. Check at ECU....plugs for each component...and if thats all good...check for continuity If that isn't it...then you might need to look into replacing those parts. But I still think its a wiring issue. __________________
"Meow, you know how fast your were going back there?" http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/ |
| Scooter; right section? Ruckus motor swap suggestions | K2e2vin | Motorcycles | 3 | 04-11-2009 04:09 PM |
| Suggestions for motor swap in 95 prelude | Mustangous | Prelude | 4 | 09-20-2007 05:22 PM |
| amp troubles | prelude_racer | Car Audio / Security / Electronic Accessories | 6 | 10-09-2006 05:06 PM |
| ecu troubles | orangepeelSi | ECU's, Electronics, and Tuning | 0 | 08-21-2006 11:22 PM |
| b16 troubles | DAMCOOLDAV | HYBRID -> ED-EF / DA | 7 | 09-28-2003 03:37 PM |
