mpfi ?'s
Old 08-17-2009, 01:23 AM   #1
Greenhorn
Rep Power: 0 civicracer04 is on a distinguished road
Default mpfi ?'s
Can I use a pr4 ecu from a 90 integra do the mpfi swap on my 88 dx, also can I use the injectors and resistor box from a b20a5 (89 prelude)? Is there anything special I need to consider since my car is an auto and the ecu is from a manual.
civicracer04 is offline   Reply With Quote
Old 08-17-2009, 02:01 PM   #2
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
Yes, prelude resistor box and injectors would work, I dont know what size the prelude injectors are, should be 240cc, but im not sure. If so they will work fine. I dont however suggest running that engine off a PR4 if its a SOHC. Itll run pig rich and stink all the time. You could run that ecu with a set of 85-87 civiccrx 195cc injectors but it still run on the rich side.
D15Beater is offline   Reply With Quote
Old 08-17-2009, 11:54 PM   #3
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
the prelude injectors attached to the b20a5 are 240cc units so they will work just fine.
You could run that ecu with a set of 85-87 civic/crx 195cc injectors but it still run on the rich side.
it would actually be running lean
agreed. don't run your sohc with the ls ecu. it will run rich, you'll lose power in comparison to the proper ecu, and your gas mileage will suffer.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
« Help! | map sensor »
Mpfi ???????? boston71 General Tech and Maintenance 8 07-08-2009 09:37 PM
Mpfi???? I_<3_my_EF Civic and CRX - EF 7 09-01-2008 12:42 PM
88 dx to MPFI??? hatukazi HYBRID -> ED-EF / DA 4 07-09-2008 01:12 AM
DP-MPFI for ZC timEspeed HYBRID -> ED-EF / DA 19 02-10-2004 02:08 PM
Dpi- Mpfi SleEPeR_CRX HYBRID -> ED-EF / DA 1 05-25-2003 02:56 PM
