mpfi swap problems
Closed Thread
Old 05-10-2007, 10:23 PM   #1
Ride:  87 Civic Hatch Si
Rep Power: 8 RcRacing72 is an unknown quantity at this point
myspace
Default mpfi swap problems
So I'm doing a mpfi swap on a 91 std hatch.
Ive modified that dx harness, (tps sensor and eacv plug)
I ran c1 and c2 into b10 and b12
Ran c1 and c2 up to blue/yellow blue/green for the distributor.
I ran all my injectors seperate.
I tested all these wires from the ecu to the connection with a volt meter and there is no break in any of the lines I ran.I matched the distributor layout with the plugs for the distributor to my street car(91civicsi) and they are in the correct spot. This car ran before I did the swap.
I'm getting no spark to my distributor, but it is getting power. I tested the ecu.
Any ideas?
Ive checked my wiring a handful of times.
thanks.
RcRacing72 is offline
Closed Thread
Several Mini-me Swap Problems... One Cause? oakley2002@cox.net HYBRID -> EG-EK / DC 3 11-14-2007 08:58 PM
major b18a swap problems! 89redracer Civic and CRX - EF 1 05-01-2007 01:41 PM
B18B swap - intermittent Vtec problems Randy Lahey HYBRID -> EG-EK / DC 3 03-30-2007 03:13 AM
JDM B16 Swap Problems!! itzkevin HYBRID -> ED-EF / DA 14 09-08-2006 09:08 PM
Problems with B18c1 swap hellspawn HYBRID -> EG-EK / DC 6 05-25-2006 11:25 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
