my civic swap.
Old 11-01-2009, 06:59 PM   #1
Ride:  civic/tegra
Rep Power: 1 kidkg24 is on a distinguished road
Send a message via AIM to kidkg24
Default my civic swap.
Ok so i put a 1998 acura integra ls B18a1 in my 1991 civic Ex 4door. the swap was painless, and the wiring seamed pritty easy.
The problems i'm haveing are when I start the car it is throwing a map sensor code "CODE 3" on my pr4 OBD 0 ecu its also throwing "CODE 7" Throttle angle sensor.
The car will start but when it is running its rough, and when i hit the throttle is will rev up , and sound ok. the seconds after i let off the gas the car will die. I start it, and it starts. same codes, and same problem. I have the 3 wire map, and tps hooked up, and the plugs are the same. I tried to switch them it really did nothing..
I want to know if anyone can tell me how they fixed this, or if anyone has the wire pinouts for the tps,map sesor? thanks
kidkg24 is offline   Reply With Quote
Old 11-01-2009, 08:07 PM   #2
Rep Power: 6 bluejcivic is on a distinguished road
sounds like a broken wire or bad ground
bluejcivic is offline   Reply With Quote
Old 11-01-2009, 08:38 PM   #3
Ride:  civic/tegra
thats what i thought, but I don't know what to test cos I can't find a wiring diagram for the tps, or the map. The harnesses have differn't colored wires then at the ecu. So i dont know what wire goes to the ecu for signal form the tps. Cos the ecu scamatic only has 1 tps going to the ecu.
I was thinking is their a power,ground, signal?
Old 11-01-2009, 09:03 PM   #4
Ride:  1991 civic wagon
Rep Power: 6 dc231581 is on a distinguished road
if you floor it does it bog or rev good?
dc231581 is offline   Reply With Quote
Old 11-01-2009, 09:05 PM   #5
Ride:  civic/tegra
both sometimes it well rev normal, and sometimes it like sounds like it drownding and will gargal.
Old 11-01-2009, 09:09 PM   #6
Ride:  civic/tegra
ok if i was going to run new wires to check if their is a break or short does anyone know what one goes where on the map.
C1 Crank Angle Sensor (ORN)
C2 Crank Angle Sensor (WHT)
C3 TDC Sensor (ORN/BLU)
C4 TDC Sensor (WHT/BLU)
C5 TA Sensor (RED/YLW)
C6 *TW Sensor (RED/WHT)
C7 Throttle Angle Sensor (RED/BLU)
C8 EGR Valve Lift Sensor - CALIFORNIA A/T Only (YLW)
C9 *PA Sensor (RED/WHT)
C10 Brake Switch (GRN/WHT)
*****C11 MAP Sensor (WHT)*******
C12 *PA Sensor (GRN/WHT)
C13 *PA Sensor (YLW/WHT)
*****C14 MAP Sensor (GRN/WHT)*******
*****C15 MAP Sensor (YLW/RED)*******
C16 O2 Sensor A (WHITE)
Old 11-01-2009, 10:15 PM   #7
sounds like your dizzy is having isues or the map sensor is not pinned right
WTB: pre swap or post swap CIVIC hatch or coupe TEXAS? tejaskid Vehicles: For Sale/Trade/Wanted 2 03-15-2008 05:02 PM
FS/Trade: Complete d16z6 swap and compete d16y7 swap joshisakson_ Parts: For Sale/Trade/Wanted 6 03-20-2007 12:06 PM
b18b1 swap, short block, trans, head, swap parts, jacksonracing supercharger egriffith45 Parts: For Sale/Trade/Wanted 4 01-21-2007 11:06 AM
fully built ls swap for sale(complete swap!!! 1500 turbozcteg Parts: For Sale/Trade/Wanted 5 10-23-2006 02:17 PM
FS: Obd0 B16 Swap Complete EF Swap Mounts, linkage,ecu Cheap Mr.slippyfist Parts: For Sale/Trade/Wanted 10 09-06-2006 09:20 PM
