Need D16z6 Swap help
Old 10-08-2009, 04:25 PM   #1
Greenhorn
Rep Power: 0 pone01 is on a distinguished road
Exclamation Need D16z6 Swap help
Ok so is my first engine swap in my 91 hatch and want everything set up and in order before i start the swap. I just want to see if i have all the parts need to make the swap and to see if there is anything that i should do while i have the motor out i.e like replace this or that part.
Parts i have
z6 head
z6 dizzy with cap and wires
spark plugs
Skunk 2 Intake valves and retainers
Skunk 2 Cam
Aem Cam gear
felpro head gasket
Skunk 2 proSeries Intake Manifold
BDL Racing fuel Rail
p28 ecu
d series si tranny
short throw shifter
complete y8 engine.
So i plan on removing most of the y8 parts and putting on the parts that i have. Before you say why not just use the complete y8 engine i was going to buy just a bottom block and build it but the guy selling it didnt want to sell it. So i wanna know from what i have listed what parts am i missing and what can i use from the y8? For the wiring shouldn't it all be plug and play since both engines use a p28? Anything that you guys would recommend doing while the engine is out like maintenance wise that would be easier with the engine out or anything that i should do while its out?
pone01 is offline   Reply With Quote
Old 10-08-2009, 06:15 PM   #2
Rep Power: 7 d16z6si is on a distinguished road
you should really use an obd1 engine harness buy a jumper from the obdo plugs to an obd1 harness that way you wont have to run any wires yourself
d16z6si is offline   Reply With Quote
Old 10-09-2009, 10:23 PM   #3
Greenhorn
do i need to use a z6 starter?
Old 10-10-2009, 12:03 AM   #4
now its a 91
Ride:  91 civic dx hb with si harness and jdm d15b
Rep Power: 6 89hatchd15b is on a distinguished road
Send a message via AIM to 89hatchd15b
I would use the starter for the block so that the mounting bolts line up. but then again aren't all d-series starters going to be the same or am I wrong?
89hatchd15b is offline   Reply With Quote
Old 10-11-2009, 05:49 PM   #5
Rep Power: 1 munchies91crx is on a distinguished road
all d series starters are the same haha get the jumper to obd1 i have the z6 swap in my rex. haha get yours up and running and we can trade i want a ef hatch.
but if ya got any questions ask me.
munchies91crx is offline   Reply With Quote
Old 10-12-2009, 01:14 AM   #6
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
I have a thing against the y series blocks. But if you're already there just use it till it spins a bearing.
Oh yeah and if your car is not si then you'll need to convert to MPFI, then convert to OBD1 and use D16Z6 injectors.
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is offline   Reply With Quote
Old 10-13-2009, 12:05 PM   #7
Greenhorn
Anyone have a really good writeup for dpfi to mpfi? Whats wrong with the y8 block?
Old 10-13-2009, 12:34 PM   #8
there are great writeups all over i have a really goodif i can get it to upload ill post it for you
Old 10-13-2009, 12:37 PM   #9
this pin out will help i cant get my write up to upload
Old 10-13-2009, 12:40 PM   #10
not that good but here is one
Old 10-15-2009, 07:34 PM   #11
Greenhorn
why would i need to convert to mpfi? I am swapping the engine and ecu to a engine/ecu that uses mpfi?
Old 10-15-2009, 07:40 PM   #12
SOHC on this!!
Yes, search MPFI swap and OBD0 to OBD1 conversion.
Old 10-17-2009, 07:09 PM   #13
is your car dpfi or mpfi if your car is dpfi then your body harness on the left shock tower is 14 pin plug if it was set up for mpfi it 8 pin plug the reason being for having to do the dpfi to mpfi swap is that your under dash harness is not set up to run for injectors or crank pos sensor
Old 10-18-2009, 05:23 PM   #14
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 26 philyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the rough
you should have something against the y series motors. the oil pumps suck!! If you have the y8 intake mani I would run that, maybe find a b-series tb to throw on there. The y8 intake manifold is best flowing stock d-series intake manifold, plus the 240 cc injectors with the y8 are bigger than the other d-series injectors.
philyphreak2127 is offline   Reply With Quote
FS: D16Z6 swap + More.... EGProject Parts: For Sale/Trade/Wanted 23 05-24-2007 11:10 AM
FS/Trade: Complete d16z6 swap and compete d16y7 swap joshisakson_ Parts: For Sale/Trade/Wanted 6 03-20-2007 12:06 PM
d16z6 swap or mini me swap newkidonblock HYBRID -> ED-EF / DA 5 09-26-2006 05:57 PM
D16Z6 swap q's slowdxracer HYBRID -> EG-EK / DC 12 05-21-2004 02:05 PM
D16z6 Swap? limpboy57 HYBRID -> EG-EK / DC 2 02-06-2003 10:02 AM
