i droped in a manual d15 usdm motor and tranny. need help with the wiring part of it. use my auto engine harness or manual engine harness? do i need to wire up the clutch pedal or something. please i need help..... honda ef9 fo shooooo....
#3 | |
Savage Reins Supreme
Ride: 88 Civic Hatch,93 Civic Coupe
I personally would get as much stuff that goes with a manual because the auto ecu will have a different mapping then the manual I beleive but dont quote me look into it more and yes u need the pedals and everything from amanual Last edited by SavageDreams; 10-23-2006 at 05:53 AM. |
remember to wire in the reverse switch so your reverse light will work!
just plug in the 5speed ecu, no conversions needed! some ef's dont have a clutch switch, but if it does your can bypass it using a button or a toggle (kill switch) for your starter! other then that.... Have fun putting in the pedal assembly! __________________
GETTO GARAGE: May be GHETTO but we get the job done! 88 CRX: B16A 60-1 turbo 94 HATCH: Daily Driven B16A (RIP) 92 EG8: Daily Driven 4DR Sleeper w/d16z6 t3/t04e turbo NA IS ALRIGHT! |
#5 | |
#6 | |
oh thats just what I thought, thats my bad. __________________
Savage Dreams |
#7 |
BOOSTED***ANA
You can use ur auto ecu if u wanna be cheap it wont run right but itl run i did the same shit in my hatch i took out a blown d15 90 civic -to a d15b7(92-95),the harness from the auto matic harness is fine but ir ur runnin a mpfi throttle bottle gotta get a SI wire harness.if u decide to use your auto harness there's going to be a plug on the rear of your block under your throttle alittle more to the left of the middle lol..i also did the auto to manual swapp also and it came outtt pefect make sure u dontt do any shortcuts..pedal's wern't bad as i thought it would be,drop ur sterring column.. dont try and squeez it in there it could bend...ur welcome..
| Do I need a 5spd ECU?Can I covert my Auto ECU to a manual? | Accordian | ECU's, Electronics, and Tuning | 8 | 12-13-2006 07:25 AM |
| How to : Convert Auto to Manual ECU P30 | natecspecr | ECU's, Electronics, and Tuning | 0 | 05-10-2005 09:25 PM |
| auto to manual swap need help | tphan4 | HYBRID -> EG-EK / DC | 11 | 04-02-2005 06:51 PM |
| pics of your auto p28 to manual | bibicarlos | ECU's, Electronics, and Tuning | 26 | 01-14-2005 06:29 PM |
| Need Help on Auto to Manual ECU Convertion | natecspecr | ECU's, Electronics, and Tuning | 1 | 01-13-2005 11:18 PM |
