need help hookin up shift light and air/fuel gauge
Old 09-12-2007, 10:57 PM   #1
Rep Power: 5 2006crxtuner is on a distinguished road
Default need help hookin up shift light and air/fuel gauge
Hey guys, i just swapped in a b16a into my 91 honda dx crx. I have a shift light that ive been wanting to hook up but not sure how to. This also goes for the air/fuel ratio gauge. So if anyone could give me some pointers and help out I would really appreciate it.
Thanks in advance.
2006crxtuner is offline   Reply With Quote
Old 09-13-2007, 01:13 AM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Shift light: hook up +12v to switched 12volt source(tapped of of under dash fuse box or something), ground to frame, and signal to the rpm signal at the distributor(usually blue wire) or the wire under the dash to the stock tach.
A/F gauge, same as above for power but signal goes to the O2 sensor.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
air/fuel gauge ? custompainter ECU's, Electronics, and Tuning 3 01-23-2007 08:44 PM
NEED Instruction on air/fuel gauge sant0r023 Civic and del Sol - EG and EK 2 11-15-2006 09:56 PM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
what is the use of installing Air/fuel ratio gauge natecspecr ECU's, Electronics, and Tuning 10 05-05-2005 03:35 PM
anyone know how to install air/fuel gauge? alldriverSiR Car Audio / Security / Electronic Accessories 8 07-07-2004 08:41 AM
