Need some input
Old 02-21-2009, 01:01 PM   #1
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
Question HELP MAhhh
Hey guys got some vids. Just wanna know what you guys think.
D15b2 with auto transmission in a 91 civic dx hatch.
Car runs fine till warmed up. Then it stalls unless you lightly rev it.
New Shyt:
head gasket
intake manifold gasket
spark plugs
wires
cap and rotor
Update: Also the CEL comes on sometimes after driving a while.
but i cant pull a code cause it goes off once the key gets turned on and off.
VIDEOS UPLOADED AND POSTED BELOW
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 02-21-2009, 01:01 PM   #2
B ( . )( . )B's
Old 02-21-2009, 02:34 PM   #3
^^ Likes Bewbies
George777's Avatar
Ride:  Rex, Yamaha Virago, CB900F Supersport
Rep Power: 119 George777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
George777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
You can still pull the code if the CEL came on. Turn the key to accessories position and pull the carpet back. It will flash any of the codes stored in there.
Originally Posted by Blanco View Post
Eat shit and fucking die you ignorant redneck.
Originally Posted by B16RacerN2NR View Post
I don't know how to do plastic surgery but I love titties, you don't see me trying to go around giving breast implants do you?
Originally Posted by phyregod View Post
Yup, Its sex on wheels. Violent, vigorous sex. With a super model. Scratch that, super model twins.
George777 is offline   Reply With Quote
Old 02-21-2009, 02:35 PM   #4
B ( . )( . )B's
even if the cel isn't on? im gonna go check.
Old 02-21-2009, 02:37 PM   #5
^^ Likes Bewbies
George777's Avatar
The ECU should still flash until you reset it.
Old 02-21-2009, 02:38 PM   #6
B ( . )( . )B's
Yea so far i got (8) and (16) lol
Old 02-21-2009, 02:40 PM   #7
^^ Likes Bewbies
George777's Avatar
TDC sensor and FI system.
I'd start by checking your timing and your injectors.
Old 02-21-2009, 02:46 PM   #8
B ( . )( . )B's
lol but here is more. here we go.
Code 1 - Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
Code 7 - TP Sensor (Throttle Position)
Code 8 - TDC Sensor (Top Dead Center)
Code 16 - Fuel Injector System
defective circuit or unplugged / defective fuel injector
Old 02-21-2009, 02:48 PM   #9
^^ Likes Bewbies
George777's Avatar
I would still check your timing first. Then work your way towards the rest.
Old 02-21-2009, 02:48 PM   #10
B ( . )( . )B's
Think it might be off a tooth or two? That could also answer why it takes a while to start.
Old 02-21-2009, 02:50 PM   #11
^^ Likes Bewbies
George777's Avatar
I'm sure the fuel has a lot to do with the starting part. Timing, too, but take the KISS method and eliminate one thing at a time.
Old 02-21-2009, 02:55 PM   #12
B ( . )( . )B's
Where the hell are the injectors on dpfi? lol im googling but all i keep finding is shiznit on dpfi to mpfi conversion.
Old 02-21-2009, 02:58 PM   #13
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
sounds like a bad ground to me with all those defective circuit/unpluged codes check ground on water neck
also the injectors are in the intake under the black box on top
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 02-21-2009, 03:02 PM   #14
^^ Likes Bewbies
George777's Avatar
There should be two--one with a brown "top" and one with a green one. I forget which one is the primary, but they are right under the little black thingy that 97hatch mentioned.
Old 02-21-2009, 03:11 PM   #15
B ( . )( . )B's
OK ill be right back with a update.
Update: I'm really leaning towards the timing. I thought it was the problem at first
but then everyone told me it couldn't be. RETARDS!
But hey at least i found and fixed a leak while i was looking around the intake.
want your input philyphreak2127 Wheels / Suspension / Tires / Brakes 73 02-14-2008 11:05 PM
Need you input!! u n v me23 HYBRID -> EG-EK / DC 12 10-18-2007 02:02 AM
Need you input!! u n v me23 HYBRID -> EG-EK / DC 0 10-15-2007 09:11 PM
Need Everyone's Input adnoh General Tech and Maintenance 3 01-26-2006 10:07 PM
Need some input StealthMode Members' Lounge 44 11-03-2005 01:41 PM
