Alright My Friend Has A 89 Hatch With A D15B7 Swap And It Throws A Code One (o2) After The Motor Gets Warmed Up, We Have Never Had This Problem Before With Other Swaps, The o2 Is Hardwired To The ECU And Has A Brand New o2 Sensor, So Idk What The Problem Is, His Cars A Tooth Out Of Time Being It Has The Wrong Timing Belt, And Ive Heard If Its Out Of Time It Burns Fuel Wrong And Triggers The o2 To Go Off Is This True, We Are Getting A New Timing Belt And Putting It On Soon Will That Fix The Problem, Im A Smart Guy I Just Cant Seem To Tackle This One
Ride: 91 honda crx
If the fuel trim is not right it will throw a o2 code just tha same as a missfire in most cars. try moveing timeing back one tooth before going out and replacing it. make sure u run it for a while then pull tha negitive battery cable off for ten or more seconds to reset the ecu.
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
you need to have the belt that matches whatever head you put on the car NO MATTER WHAT. fix that, then diagnose your other issues.
| Map Sensor Problem w/ JDM b16 | J240sx | Engine Building | 7 | 01-15-2008 10:38 PM |
| Map sensor problem with B16 | J240sx | ECU's, Electronics, and Tuning | 0 | 01-07-2008 09:57 PM |
| Someone Please Help!!!!! O2 Sensor Problem | sir92hatch | Civic and del Sol - EG and EK | 1 | 11-29-2007 02:58 PM |
| 02 sensor problem | 92d15b | ECU's, Electronics, and Tuning | 1 | 05-18-2005 04:13 PM |
| O2 Sensor Problem Please Help ? | rexheadb16a | ECU's, Electronics, and Tuning | 0 | 06-02-2003 06:18 PM |
