obd1 b18b1 into 91 civic standard
Old 06-28-2009, 10:48 PM   #1
Ride:  89 civic ef
Rep Power: 3 hondaracercrf3 is on a distinguished road
Default obd1 b18b1 into 91 civic standard
I have a 1991 honda civic i just put in a obd1 b18b1 with a p75 ecu
im using a obd0 b series harness but i switched out the distributor plugs to obd1
since im using a obd0 harness it only has a 1 wire o2...i need a 4 wire o2 so im just going to wire it straight to my ecu...
so im running without an o2 sensor...and it runs fine but the problem is..is that it is a bitch to start....you have to sit there and crank on it for a while...and it will start and die start and die....im also using single cam injectors with the obd0 clips....i was wondering if anybody knew that the problem would just be not having an o2 sensor and running obd0 clips with single injectors?? or would it be somthing else...
i really need some help please
hondaracercrf3 is offline   Reply With Quote
Old 06-29-2009, 11:43 AM   #2
pappaj's Avatar
Ride:  89 CRX SI (LS)
Rep Power: 5 pappaj is on a distinguished road
you should be using the same injectors that go with your ecu, as far as I know.
pappaj is offline   Reply With Quote
Old 07-01-2009, 01:31 PM   #3
Rep Power: 4 blasterman87 is on a distinguished road
what obd are the injectors? if there obd1 injectors you have to cut/solder the plug for the resistor box...
blasterman87 is offline   Reply With Quote
Tags
b18, bseries, civic, ef9
P75 Socketed for Hondata S200 ECU B18B1 Integra OBD1 RSS-Bot Auctions 0 11-15-2008 12:50 PM
B18B1 swap in 90 DA. OBD0/OBD1 JDM power HYBRID -> ED-EF / DA 2 10-29-2008 03:21 PM
92-95 Acura Integra LS OBD1 B18B1 Ignition Distributor RSS-Bot Auctions 0 04-20-2008 01:43 AM
jdm b18b replacing obd1 b18b1 questions. spidermancivic HYBRID -> EG-EK / DC 1 11-17-2005 06:33 PM
OBD1 B18b1 into a 99 si? Red99Si HYBRID -> EG-EK / DC 3 03-07-2004 03:43 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
