overheating
Members have access to more features and see fewer ads! It's free, what are you waiting for?
Old 07-01-2008, 06:57 PM   #1
Ride:  99 gmc 1500 and now a 91 crx si
Rep Power: 0 korno is on a distinguished road
Send a message via AIM to korno
Default overheating
my car is overheating at stops low gears. i turn on the heat and it goes down high speeds im good. ol i checked the fans and they work, i dont see leaks or puddles under the car even after i let it run hot for 20 minutes. but heres the thing that got me real confused i fill up the radiator with fluid and the reserve ad recomended about a gallon of fluid i have put in the past 2 weeks. and everytime i check the fluids when it overheats its bone dry. i did buy the car used so im still figuring out whats wrong with it. could it have been that bone dry that its taking all the fluids? any and all help is appreciated. thanks in advance.
korno is offline   Reply With Quote
Old 07-01-2008, 07:13 PM   #2
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 55 Luis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant future
Do you have a crack on your radiator that you can't see like I did? How long has it been since you replaced your thermostat? Is your head cracked, warped and has your car overheated? If so, you may have to replace your head gasket and or get your head, what is it, shaved or milled in order to get it straigtened out?
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406
Originally Posted by Blanco View Post
Headers and a turbo, eh? Brilliant advice, Doctor. Simply brilliant.
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 07-01-2008, 07:56 PM   #3
i bought this car little over a month ago so as far as i know no the thermostat has not been changed. there are no puddles when the car sits over night or when i keep it running like for the 20 minutes i did toay to see if there were any leaks. theres no puddles of any fluids at anytime. radiator seems old but fine no leaks to the eyes and no radiator fluid anywhere.
Old 07-01-2008, 10:22 PM   #4
żUnKnOwN?
INJEN78's Avatar
Ride:  91 civic si
Rep Power: 68 INJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant futureINJEN78 has a brilliant future
probably the headgasket has a small leak.and its getting into the cylinder...is there any colored smoke coming out of the exhaust??
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 07-02-2008, 03:59 AM   #5
nope none at all even when it sits all night and i start it up nothing
Old 07-02-2008, 04:07 AM   #6
Bkkfarang's Avatar
Ride:  95eg extreme single cam / 06jazz hks turbo soon/
Rep Power: 7 Bkkfarang has a spectacular aura aboutBkkfarang has a spectacular aura aboutBkkfarang has a spectacular aura about
pin hole leak in the radiator only steam escaping can be very hard to find , or even a bad water pump,
Bkkfarang is offline   Reply With Quote
Old 07-02-2008, 08:43 AM   #7
Rep Power: 3 93y7 is on a distinguished road
whats the oil look like? that will let you know if theres any internal leaks. if its milky or watery you have a problem
93y7 is offline   Reply With Quote
Old 07-02-2008, 09:03 AM   #8
VTEC or NOTEC
Justin66's Avatar
Ride:  1990 Intergra GS/XSi
Rep Power: 12 Justin66 is a jewel in the roughJustin66 is a jewel in the roughJustin66 is a jewel in the roughJustin66 is a jewel in the rough
Rad cap check and see whats going on in your overflow tank.
Here is a tip, get the car nice and warm, preferably in the morning while its still cool out or when there is condensation on your car, get out real quick open the hood and look for steam. I had to do that 3 times before i finally saw some steam and rad fluid burning on the block. It was a small coolant hose clamp that was loose going to the intake manifold.
Get a flush and maybe a pressure test if you cant find it right away. And like everyone else said check the main signs of a leaking HG.
90 Integra GS/ XSi
- JDM B16A SiR2 w/ full exhaust & short ram
- Skunk2 stage 1 cams (not installed yet)
- J1 Tranny
- H & R lowering springs
- Rear strut bar and front camber kit
- HKS Hi-Power exhaust
- Powersteering removed
Sk2 Cam gears and Intake Manifold soon.
Justin66 is offline   Reply With Quote
Old 07-02-2008, 05:09 PM   #9
well today when it started to overheat some steam came up from the dash and it was a strong smell of antifreeze heater core maybe? and i do think the water pump is gone
Old 07-02-2008, 09:25 PM   #10
VTEC or NOTEC
Justin66's Avatar
Well anything from the interior will be the heater core. Check for any wet spots on the carpet or mats, that should guarantee the heater core leaking.
Usually if the water pump is going you should be able to hear a squeaking or howling. From a bearing i believe.
If you cant find it yourself a rad place would be your best bet.
Good luck and keep us posted.
90 Integra GS/ XSi
- J1 Tranny
Forum Jump
overheating? charlesb2003 Civic and del Sol - EG and EK 6 04-22-2007 05:21 PM
Overheating rexsk8er Forced Induction 6 09-11-2005 12:15 AM
overheating? ericL HYBRID -> EG-EK / DC 23 08-25-2005 12:31 AM
car overheating SlushboxTeggy General Tech and Maintenance 24 12-16-2004 06:31 AM
Overheating... randerson165 General Tech and Maintenance 4 03-04-2003 01:56 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
