P0420 code after installing header
Old 03-28-2008, 12:22 AM   #1
Rep Power: 0 vg_Ace is on a distinguished road
Default P0420 code after installing header
So I am not finding any answers on my kia forums so I thought I would ask you guys. Besides owning a 91 crx HF I also own a 2005 Kia spectra 5. I recently bought a header and midpipe for the car. After waiting 5 months I finally get it. The stock setup was as follows:
Exhaust manifold with 1st 02 sensor, catalytic converter, downpipe, midpipe with Flex part and after that 2nd 02 sensor, cat, resonator, more pipe and muffler.
The header and midpipe eliminated both of the cats. Not only was this freakishly loud, but it is also now throwing a P0420 code. I was advised to buy an 02 extender off of ebay. It costs $9 and $4 to ship. Needless to say it is crap and does not do anything. It may work for your car but it did not work for mine. I already had my stock cat welded back onto a section of the midpipe closer than it was during stock configuration but it is still behind the 2nd 02. What I am going to do now is go to the same exhaust shop and have them drill a 02 bung behind the cat. Then I will ahve to cut and splice in more wire to physically extend the 2nd 02 sensor BEHIND the cat. I was told that the distance matters by some and that it doesn't matter if it is right behind by others. Anyways I will see what the shop says.
My question is this: what care should I take when extending the wires? I already have the correct gauge wire, and I am going to solder and heat shrink the wires to give a good connection, but is there anything else I should worry about? I mean has anybody that owns a Honda ever had a P0420 code thrown for something like this? What did you do? Thank you all for reading.
vg_Ace is offline   Reply With Quote
Old 03-28-2008, 12:39 AM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
lock it double post
Old 03-28-2008, 12:51 AM   #3
Yes any moderator please delete this thread. Didn't realize there was a section for Non-hondas.
Forum Jump
P0420 Error Code 00 civic Kanned General Tech and Maintenance 7 08-20-2007 09:16 PM
Installing my header. 2000Si General Tech and Maintenance 8 05-24-2007 09:44 PM
Engines with the fastest piston speeds asmallsol Members' Lounge 10 08-25-2006 09:01 AM
codes civichbwithb18a1 HYBRID -> ED-EF / DA 1 10-03-2003 03:24 PM
Header Info 4 Na Junkies JDMilan Engine Building 11 05-13-2003 09:28 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
