passenger cv axle will not go into the Hub???
Old 08-10-2008, 03:22 AM   #1
Banned
Ride:  89 Civic Hatch
Rep Power: 0 TravisCadello is infamous around these partsTravisCadello is infamous around these partsTravisCadello is infamous around these parts
myspace
Default passenger cv axle will not go into the Hub???
Ok, I worked on this fucker for 2 hours and the drivers side slid right in and i hammered the rest in. the passenger side for some reason will not go in for the life of it! i feel the lines or threads in the center of the brake rotor and their fine. and i look at the cv axle and the little stripes or threads are good maybe a barely little messed up. i put grease and hammered it as hard as i could while spinning the hub. do i need a new cv axle or what??
TravisCadello is offline   Reply With Quote
Old 08-10-2008, 10:35 AM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
the hub is different from a std civic and other models. is yours a std ?
Old 08-10-2008, 02:15 PM   #3
Ride:  91 ef B18 swap w/AC!
Rep Power: 1 red91efhatch is on a distinguished road
I was thinking the same... fit it outside first, and when it comes to sliding the axles in it hsould be nmore about finesse then force.
red91efhatch is offline   Reply With Quote
Old 08-11-2008, 12:41 AM   #4
Banned
myspace
Yes, Its standard, but what werd is their the same axles i was using before and the sam transmission and it still wont go it. its like somethings stopping it. but if i take the axle out the tranny and hammer it in on the outer side of the hub it goes in no problem. its werd if it goes in on the opposite side then i'd think it should go in the other side no problem. what else could this be???
Old 08-11-2008, 12:42 AM   #5
HS TECH
AHHVTEC's Avatar
no clue put something on it to lube it up good,
Old 08-11-2008, 12:58 AM   #6
Banned
myspace
i put a ton of wheel bearing grease and still didn't go in. I'm gonna try in buy a new axle for that side its all screwed up anyways.
Old 08-11-2008, 01:35 AM   #7
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 89 K2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud of
Send a message via AIM to K2e2vin
You shouldn've have tried to hammer it in. The splines probably aren't lined up or it's a little crooked.
1988 Honda Civic STD-more mods than I want to list
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 08-11-2008, 01:39 AM   #8
Banned
myspace
Thats what i thought thats why i tried spinning the hub and hammer softly and it never would find a path to go in. its like somethings blocking it.
Old 08-11-2008, 01:41 AM   #9
K2e2vin's Avatar
I had that issue with my Accord. Patience eventually paid off(took a lot of wiggling and spinning). You should clean the splines and inspect them.
RIP
Old 08-11-2008, 01:42 AM   #10
Banned
myspace
i cleaned them greazed them and everything. i took 2 hours of trying and trying. i think im gonna buy a new axle. hopefully that works.
Old 08-11-2008, 01:44 AM   #11
K2e2vin's Avatar
Good luck! If that doesn't work, maybe the splines on the hub is messed up.
RIP
Old 08-11-2008, 01:46 AM   #12
Banned
myspace
In that case would i have to replace it all?
Old 08-11-2008, 01:51 AM   #13
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 107 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Yes, if something is messed up and cant be fixed what do you usually do next?
Looking for a P28 and B-series turbo parts, PM me.
Old 08-11-2008, 01:53 AM   #14
K2e2vin's Avatar
It would be easier to just replace the whole knuckle with a known good one but a shop can press in new hubs pretty easily. You can change your wheel bearings while you're at it. If you have a HF/Std and plan on swapping motors in the future, might as well swap in DX/Si/EX knuckles and axles.
RIP
Old 08-11-2008, 01:57 AM   #15
Banned
myspace
whats the diffrence in the si axles?
Old 08-11-2008, 01:58 AM   #16
HS TECH
AHHVTEC's Avatar
there smaller
Old 08-11-2008, 01:59 AM   #17
K2e2vin's Avatar
The DX, Si, and EX hubs use larger ends(larger diameter/more splines).
RIP
Old 08-11-2008, 02:00 AM   #18
Banned
myspace
and if i swapped them would the Si axles fit my D- series tranny?
Old 08-11-2008, 02:00 AM   #19
HS TECH
AHHVTEC's Avatar
the hub axle holes on the std are larger than the others
Old 08-11-2008, 02:01 AM   #20
Banned
myspace
And these wont help me at all as of now but only later on down the road right? or are they stronger and better?
Old 08-11-2008, 02:02 AM   #21
K2e2vin's Avatar
other way around dude. Std/HF are smaller.
Yes. Only the outer ends(hub-side) of the axles are different.
RIP
Old 08-11-2008, 02:02 AM   #22
HS TECH
AHHVTEC's Avatar
well i would have thought the same also but i just done this about a week ago
Old 08-11-2008, 02:05 AM   #23
